First post, by xtv
Hi all,
After being a Vogons reader for quite some time (this forum is amazing!), it came the time for my first post. I believe I'm following all the rules, please forgive me if I've missed something.
I have two IDE CD drives that I was hoping to use on my retro PC build, one being a Sony CDU-5211, which was barely used, and the second a HP CD-RW 9300 that I bought a new old stock on ebay. Both were working 100% the last time I've played with them. I even tested the HP to burn a couple of CD-Rs in low speed, which worked fine.
Now this time I tried using a USB to IDE adapter on my modern PC to burn a windows 98 ISO with the HP drive, and it suddenly wouldn't read any CDs anymore. I then swapped to the Sony CD-ROM, same behavior.
Tried a couple of pressed CDs, one Linux installation CD-R that I know to have been burned properly, a few cd-rw, nothing! For both drives it behaves as it loads the tray empty, won't even try/struggle to read it. Led blinks a couple of times and it gives up.
Now I tried both these drives on my retro PC (a socket 370 Motherboard with celeron mendocino) with native IDE and Ms-Dos 6.22 installed. Both get detected by Bios, but same behavior, won't read anything. MSCDEX set the drive up, when I do a D: and DIR, I get the fail/retry/abort dialog as if there's no CD in.
Now I replaced the motherboard for a second socket 370 motherboard; exact same behavior above!
have replaced IDE cables, no luck.
I'm really intrigued, how can possibly be the two drives 'dying' at the same time? The HP is brand new, haven't used it 10 times.
Does anyone have any suggestions? At this point I'm clueless.
Could the USB to IDE adapter have killed both drives data transfer ability, even though they get detected in BIOS?
PS, I've used an external ATX psu to power these drives when using the usb to IDE adapter (not the same inside my modern pc). I'm thinking, could the IDE and power rail grounds inside the drive not be connected and that caused a high potential difference in the ide data and have burned the drive, whilst it still gets detected by the bios?
Could one of the CDs I've tried have permanently damaged both drives? Never seen this before, but at this point I'm not discarding anything.
Any ideas to try? I'm pretty frustrated to have likely killed this new old stock HP drive already ☹️
Thanks everyone.
