HWiNFO for DOS resurrected !
Reply 880 of 897, by Mumak
Released v6.2.3:
  • Improved detection of Cirrus Logic CL-GD5420 and older adapters.
  • Improved detection of XGA adapters.
  • Minor updates.
Reply 881 of 897, by Grzyb
There's a feature in Checkit that I could use in HWiNFO as well...
The attachment 1.png is no longer available
The attachment 2.png is no longer available
See IRQ 10 - Checkit detects that it's serviced by some driver/TSR, and displays its name.
Zaglądali do kufrów, zaglądali do waliz, nie zajrzeli do dupy - tam miałem klimatyzm.
Reply 882 of 897, by Grzyb
Grzyb wrote on 2021-05-01, 20:27:
Somewhere between 6.0.2 and 6.1.0, HWINFO lost the ability to correctly recognize Celeron 266. Works fine in 6.0.2, but in 6.1.0 […]
Works fine in 6.0.2, but in 6.1.0+ it's misrecognized as Pentium II:
The problem seems back in 6.2.3:
The attachment 622.png is no longer available
The attachment 623.png is no longer available
Reply 883 of 897, by Mumak
Grzyb wrote on 2024-04-28, 04:15:
The problem seems back in 6.2.3: 622.png 623.png […]
Please attach LOG file that includes also the second (CPU details) screen and respective DBG file of both versions.
Reply 884 of 897, by Grzyb
Mumak wrote on 2024-04-28, 06:25:
Here you are...
Reply 885 of 897, by crusher
@Mumak:
Thanks 1000 times for still working on that "old" software.
It safes our lifes for us retro DOS lovers 😀
Reply 886 of 897, by Many Bothans
Thanks for all the work!
Here's the log from my resurrected Zenith Z386SX-20 system. CPU, L2 Cache and VGA spot on.
  • Zenith Z386SX-20, 8MB FPM, Video 7 1024i, Unhoused
  • AOpen AP43, Am5x86-133@160, 1MB L2, 128MB FPM, Stealth III S540 32MB Savage4, SB32 w/ 8MB
  • Asus CUV4X-E, P3-933, 512MB PC133, Hercules 3D Prophet II MX 32MB, SB Live!
Reply 887 of 897, by Mumak
Many Bothans wrote on 2024-07-26, 18:08:
Thanks for the feedback. If any issues, please also attach the DBG file (run with -d switch).
Reply 888 of 897, by leon22
HWInfo 6.2.3 is not able to detect Soundblaster 16 (CT4170):
The attachment IMG_8345.jpeg is no longer available
The attachment IMG_8348.jpeg is no longer available
Gigabyte GA-486AM (BIOS Nov 7, 1995 REV.A)
AMD Am5x86 - 133MHz
64 MB RAM
https://funwithretrocomputers.blogspot.com/
Reply 889 of 897, by Mumak
leon22 wrote on 2024-09-15, 20:44:
HWInfo 6.2.3 is not able to detect Soundblaster 16 (CT4170): […]
AMD Am5x86 - 133MHz
64 MB RAM
Please attach the Debug File which you can create by running "HWiNFO -d"
Reply 890 of 897, by leon22
Mumak wrote on 2024-09-15, 22:13:
AMD Am5x86 - 133MHz
64 MB RAM
Here you go:
The attachment HWINFO.zip is no longer available
Thank you
Reply 891 of 897, by Mumak
leon22 wrote on 2024-09-16, 15:17:
Here you go: […]
AMD Am5x86 - 133MHz
64 MB RAM
Here you go:
Thank you
Thanks. At which port is the card set?
Reply 892 of 897, by leon22
Mumak wrote on 2024-09-16, 15:51:
Here you go: […]
Here you go:
Thank you
The attachment IMG_8336.jpeg is no longer available
Port 280, IRQ 5
Reply 893 of 897, by Mumak
leon22 wrote on 2024-09-16, 17:17:
Here you go:
Thank you
Port 280, IRQ 5
Thanks. I have posted a new version 6.2.4 in the initial post of this thread. Please try it and let me know if it's fixed now.
Reply 894 of 897, by leon22
@Mumak
Looks good. Thank you very much!
The attachment IMG_8352.jpeg is no longer available
The attachment IMG_8351.jpeg is no longer available
The attachment IMG_8350.jpeg is no longer available
Reply 895 of 897, by Mumak
Thanks for the feedback!
Reply 896 of 897, by ElBrunzy
Hi Mumak, it's a great honor for me to write to the author of HWiNFO as I was always very much impressed by those software. I know detection of hardware has always been a challenge and such tool always proved so handy for us.
I just finished a new build, it was a fun project where I could found how slow I could run a p54cs 100mhz pentium on this SOYO 5TB board, which is 33mhz after some modification. Now I think the bus multiplier is 1.0 and the cpu run at 33mhz which HWiNFO reported correctly at 37mhz (just like CPUINFO, i wonder why it's not 33mhz exactly, maybe some conversion artifact)
Everything was reported correctly on that computer except that little detail, now I dont know why it decided the GUS was the soundcard flagship of this computer when there was also an AWE32 and an SAAYM (ok I understand the SAAYM might not be the one expected for this title, but the SB?). What puzzle me is that it report 10mb of ram for the GUS, is it something I am missing but I think I would had expected 1024KB here and not 10,240KB, dont you agree ?
Reply 897 of 897, by Mumak
ElBrunzy wrote on Today, 03:43:
Hi Mumak, it's a great honor for me to write to the author of HWiNFO as I was always very much impressed by those software. I kn […]
Thank you 😀 You're right, it's a bug in testing GUS DRAM size and it shall be fixed in the next version.
