First post, by Kahenraz
I just bought a Socket 370 motherboard with a 440LX chipset. The fastest Intel processor it supports is the 533Mhz Mendocino. Are there any other processors I should consider, such as from VIA, which might be faster or more flexible for a retro system with SetMul?
I don't think that buying any of the Intel Mendocino processors slower than 533Mhz one would provide any benefit, since it's only a difference in multiplier.
Reply 1 of 10, by st31276a
That is what it supports yes. I would test to see if a higher clocked coppermine will run at reduced speed on the 66 bus. However, on this platform a 66 bus is a real bottleneck.
Reply 2 of 10, by AlexZ
Buy a few Mendocino Celerons 400. One of them will work at 500Mhz (6x83.3Mhz). Get a Riva TNT and it will serve you well.
Pentium III 900E, ECS P6BXT-A+, 384MB RAM, NVIDIA GeForce FX 5600 128MB, Voodoo 2 12MB, 80GB HDD, Yamaha SM718 ISA, 19" AOC 9GlrA
Athlon 64 3400+, MSI K8T Neo V, 1GB RAM, NVIDIA GeForce 7600GT 512MB, 250GB HDD, Sound Blaster Audigy 2 ZS
Reply 3 of 10, by Kahenraz
st31276a wrote on 2024-01-27, 18:55:
I didn't think that you can run Coppermine voltages on these older boards. I also read that the 440LX chipset is not compatible with these instructions. I experienced this issue previously with a 440EX:
Windows 98 can hard lock when pairing a Pentium 3 with an older 440 chipset
Reply 4 of 10, by PcBytes
LX cannot address SSE. I have 566 and 633 Celerons here - both will POST on a Zida LX98-AT but hang up randomly. (sometimes even when on BIOS screen.)
Reply 5 of 10, by Kahenraz
Out of curiosity, does anyone know how the chipset interacts with SSE instructions to cause them to fail?
Reply 6 of 10, by st31276a
Interesting. I do not think the chipset touches instructions directly. Perhaps it is more of a microcode problem.
Reply 7 of 10, by Kahenraz
I found that my motherboard (ASUS MEL-M) had a BIOS update which states that Coppermine stepping B0 is specifically supported. I thought that this was very interesting, since it was mentioned previously that the 440LX cannot address SSE.
Well, it works and it doesn't. I think that it's "supported", but SSE is stills broken. When testing a TNT2 with driver version 43.45, the system hangs at startup. This is not the case with Mendocino CPUs. I tried using a Coppermine Celeron 533A (SL46S), the lowest spec one I could find.
https://www.asus.com/supportonly/mel-m/helpdesk_bios/
Add microcode update support for Coppermine B-0 stepping
I suspect that it might be possible to get it working with an older driver that doesn't use an SSE codepath, but I feel like I would end up encountering other random crashes in similar instances where SSE instructions are accessed.
Reply 8 of 10, by Kahenraz
AlexZ wrote on 2024-01-27, 19:08:
When testing a Mendocino Celeron 400Mhz overclocked to 500Mhz with a 83.3Mhz FSB and a TNT2 Pro I got the following results in 3DMark99:
3660 3DMarks
4593 CPU 3DMarks
With a Mendocino Celeron 533Mhz (not overclocked) I got the following results:
3426 3DMarks
4477 CPU 3DMarks
I wasn't able to overclock the Celeron 533 to 666Mhz, but I was able to get a small boost to 600Mhz (8*75Mhz):
3829 3DMarks
5071 CPU 3DMarks
Reply 9 of 10, by rmay635703
There used to be adapters that allowed any 66mhz celeron to install-766mhz. I’ve never had much luck with adapters
Reply 10 of 10, by AlexZ
Kahenraz wrote on 2024-02-22, 22:25:
3829 3DMarks
5071 CPU 3DMarks
You may be able to get Mendocino 433 to work at 6.5x83.33 (541Mhz) provided you have sufficient samples (at least 5). 500Mhz is the safest OC though. 600Mhz will not be stable.
