3Dfx Voodoo flimmer?
First post, by oh2ftu
Hi there.
I have this Voodoo Dragon, that seems to work fine in both Quake and Quake2.
However, especially in the console, there are vertical shifts/line occurring, kind of like a flimmer.
Not really noticeable in gameplay, but sure is in the console. Quite hard to take a picture of this - I don't have any capture hardware
I've yet to check for any loose pins, but where might this come from? The other voodoo does not have these symptoms - although the board revision differs a tiny bit.
I don't have a passthrough cable (yet) which might have something to do with this.
My guess would be something with the FBI and/or ramdac/switch?
Reply 1 of 2, by Imperious
I guess You mean Flicker or flashing?
You don't need any special pass through cable, You can use a VGA cable as long as one end is male and the other female.
Seems a bit odd if only in the console. Maybe try some other games, especially ones that use glide. Quake and Quake 2 use opengl, or minigl in the case of the voodoo card.
Also You could try Tomb raider 3dfx version in dos.
Reply 2 of 2, by wiibur
From what I understand, the output on some voodoo 1 and 2s can be pretty noisy. I've seen reports of vertical lines, horizontal lines, and have experienced scrolling lines at a 45 degree angle on one of my voodoo 2 cards. These are usually like "shadow lines" or bands of alternating opacity.
Are you on an analog or digital monitor? Try a CRT if you are using an LCD. Or try adjusting the vertical and horizontal clock signal on the digital monitor (try auto-adjust first). Other users have used a low pass filter to resolve their issues. I've also seen someone report that a VGA splitter/signal booster box resolved their issue.
Post a capture or video from your phone if possible. Maybe these examples can help you describe what's happening.
Example of horizontal noise: https://www.youtube.com/watch?v=Qk0eCpgo6_c
Example of vertical banding: download/file.php?id=45224&mode=view
Example of diagonal banding: download/file.php?id=129066&mode=view
Example of snow/glitches (voodoo 3 issue): https://www.youtube.com/watch?v=zVBMC8194ps
