NAS Organization tips?
First post, by dumpsterac1d
I have purchased an Asustor 4-bay NAS with 2 network ports. The initial urge is to serve files directly to my old computer (Win 3.1, Win 98, and Win XP on separate HDDs) through SMB 1 with one dedicated net port. Now I know that SMB1 is a security vulnerability, but seeing as that physical port should be inaccessible to anything remote, and inaccessible to the wider internet, I am not super concerned.
What I am concerned with, however, is how to logically separate everything so that it makes sense. In addition to serving disc/disk images and having a place to store tons of backups of autoexecs, configuration files and drivers, I want to use the NAS for more modern things, like serving video/audio to a few devices, and storing a giant bank of roms and images to a modern computer, a Sega Saturn, possibly a PS2, and eventually a couple of MiSTers.
I think what I'm getting most confused about is separating logical volumes vs sharing different folders as drives. What would be the downside of having a massive volume and just separating it all into various folders, which then get assigned drive letters (and physical ports) if need be? Vs of course splitting the entire pool into volumes depending on usage.
Looking forward to any/all recommendations.
PS - I'm going to leave the entire NAS off the internet for the time being, seeing as a ton of ransomware attacks are active (as of this posting), so most of the data will be filtered through the windows security on my modern desktop.
Reply 1 of 2, by wiretap
You can always put the 2nd NIC on a VLAN and separate it so there's no internet access if you don't need there to be any. Or a separate network switch if yours doesn't support VLANs. Then use FTP for all the retro devices to access it. You can block FTP at your main network gateway/firewall as well. Not sure what the Asustor has in terms of logical network port access control.
My Github
Circuit Board Repair Manuals
Reply 2 of 2, by dumpsterac1d
wiretap wrote on 2022-06-03, 19:44:
One of the reasons I'm enabling SMB specifically for the old computer is so I can load disc images directly from the network rather than transferring them to the smaller hard drive each time. So FTP won't work, primarily because you can't select files from image software through FTP.
Also would like to experiment with "installing" games to a network drive and attempting to load them and see if any errors pop up. I would imagine most DOS titles from 94 and earlier would load just fine if run from a net connected 98 install (or 3.11 for that matter).
I do enjoy the vlan idea, I could definitely do that later on once i get more robust net hardware, and thankfully asustor's configs go pretty deep.
