OpenGLide Glide Wrapper
OpenGLide 0.09 Release Candidate 5
OpenGLide 0.08
OpenGLide 0.07 Beta 5 […]
OpenGLide 0.08
Date: 08-May-2002
File Size: 35 kByte
OpenGLide is a freeware Glide wrapper to convert Glide calls from 3dfx graphic cards to OpenGL calls. Basically you can play a lot of games programmed for the Glide API on non 3dfx cards as NVidia GeForce series and others. It works well with Red Baron II/3D. Just unzip it and drop the file called 'Glide2x.dll' into your game's main directory to control only this game's GLide setup. Upon first start an 'OpenGLid.ini' file will be created that controls your Glide Wrapper setup for your graphics card.
OpenGLide Version 007 Beta 5 reportedly works better with Red Baron 3D than newer versions but there are other reports stating that OpenGLide 0.09 Release Candidate 5 works great as well. Just find out what is best for you.
ATI graphics card users should change the 'IgnorePaletteChange' setting within this file to the following:
IgnorePaletteChange=1
Red Baron II/3D players with ATI cards should also disable Sun Glare in the game setup options to get the best performance from their ATI cards.
