First post, by Peter.Mengel
Can i use them in one pc together or will i get in DOS compatiblity problems cause both using the same irq, or could i change them to 1 and 2 and use the one i want to in case of real OPL3 vs SB16 Emulation. Thanks
Reply 1 of 3, by appiah4
What OS are you going to use them in? For DOS, there is no reason to initialize the Live! card at all if you have the SB16 in there. For Windows, you can just disable Live!'s Legacy emulation and route SB16's Line Out to Live!'s Line In. Or disable SB16 altogether in the hardware profile.
Reply 2 of 3, by Peter.Mengel
appiah4 wrote on 2022-03-09, 13:04:
Win98 and its DOS Mode. So outside the DOS Gui shell. My Aztech 2320 runs only on SB Pro Mode, no SB16 no General Midi Support.
Thats why i want to add the Live Card.
Reply 3 of 3, by appiah4
No real need for SB16 over Pro in DOS tbh..
