NEC Multisync 3d nec-jc1404hma repair help?
First post, by ArcadEd
Hi Everyone,
So I have repaired my fair share of TVs and Arcade Monitors. Upon opening up this Monitor I realized there is a bit more here than your typical CRT.
What is going on right now is the there is a single, really bright, line though the center, horizontal. Based on what I have read it's possible the vertical has collapsed. Some repairs have been replacing the vertical IC, others replacing caps. None of these were on this crt though.
Does anyone have experience repairing this particular monitor? What would a good starting point be?
I have tried it on another computer, same issue.
Line does not appear unless it has an active signal (it's not there when just turning the monitor on).
I removed the back and just did a quick scan for bulging Caps and fried ICs. Nothing really looked bad, but there is a lot to look at. I'll discharge it and take a closer look once I have a starting point.
I have the service manual in PDF.
Thanks
Reply 1 of 23, by BitWrangler
Hope this jumps you to the right section "Single Horizontal Line"
https://www.repairfaq.org/REPAIR/F_monfaq7.html#MONFAQ_002
Reply 3 of 23, by mkarcher
BitWrangler wrote on 2021-12-05, 19:56:
One typical fault I already encountered in audio amplifiers and CRT oscilloscopes I do not see explicitly mentioned in the Repair FAQ (great document collection, BTW!) is "shorted bypass cap". If the bypass cap is part of an RC filter for the supply voltage, a shorted cap doesn't necessarily cause any damage, because the R before the cap limits the short circuit current. The shorted bypass cap still causes loss of the supply voltage for a part of the circuit. So don't just check caps with an impedance (ESR) meter and be happy about extremely low value, but als check them with a DC continuity tester for actual shorts.
Reply 4 of 23, by pentiumspeed
Vertical IC dies usually when retrace kick capacitor dry up. This capacitor is next to vertical IC. Also there will be vertical power supply has a fusible resistor somewhere else open also. Confirm that they were defective and replace them.
Cheers,
Great Northern aka Canada.
Reply 5 of 23, by ArcadEd
pentiumspeed wrote on 2021-12-05, 22:02:
Cheers,
Thank you
Reply 6 of 23, by ArcadEd
Cheers,
So according the schematic I believe this is the Vertical IC. I'm fine at swapping out parts, but troubleshooting these things is a different story. Arcade monitors I usually just have to do a cap kit, or replace a flyback from time to time. I'm afraid I may be getting in over my head with this but figured with the right help maybe I can get it working 😀.
Am I in the right place? IC 402? Attached to the big black heatsink?
Thanks again.
Reply 7 of 23, by Unknown_K
Anybody have the Nec 3ds service manual?
Reply 9 of 23, by pentiumspeed
Check the part number on this IC and you will get a data sheet on this IC so you can know which capacitors are for the vertical IC and replace them all and find the fusible resistor and replace this as well. The vertical IC supply will be shown in the data sheet and follow this back to the fusible resistor. Also check diodes.
Cheers,
Reply 11 of 23, by ArcadEd
I got the data sheet for the IC, but I wanted to ask about some of the resistors. I tried to take a close up picture, is it normal for them to have like that black leakage? Some have green corrosion as well.
Reply 12 of 23, by pentiumspeed
That black thing with white band is diode, rarely fail, but check it with your meter to confirm is good. What is the two capacitors values are? These capacitors' juice is what cause corrosion and got dried up, which blown that vertical IC. When this happens, one more thing will be also blown is fusible resistor somewhere else that supply the vertical IC's supply.
You're forgetting my comments. They will be true. I have done these vertical IC failures repair all the time back in the day when CRT ruled the era. Real reason is the capacitor kick, well kicks the beam that is ending at bottom of scanning field up to top to begin new field, got dried up and killed the vertical IC and in turn blown the "fuse" fusible resistor, always.
ALWAYS confirm by checking various items items IS defective or good as I had, I outlined and replace only the defective. Do not just assume they are bad and replace without knowing except the capacitors. Refer to the vertical IC schematic example and replace these capacitors as you cannot check unless you have a ESR meter on hand. Which is not what multimeter's have in their features.
Cheers,
Reply 13 of 23, by ArcadEd
pentiumspeed wrote on 2021-12-19, 23:00:
That black thing with white band is diode, rarely fail, but check it with your meter to confirm is good. What is the two capac […]
Cheers,
I believe your comments. Just trying to narrow things down before I go into unknown territory for me like reading data sheets and schematics 😀. Physical inspection of the resistors and such 😀.
Do you mean what are the value of those caps as written on them? Obviously, like you mentioned, I can't test them correct?
35v 100uf.
Thank you.
Reply 14 of 23, by pentiumspeed
Not need to, if you don't have ESR meter.
Yes, you do need to read the vertical IC marking and get data sheet via google for the vertical IC and this will provide you with enough information where to trace like vertical IC supply back to the source of supply and in that supply circuit there should be a fusible resistor in series, that might be open, which diode is used and capacitors for this.
If you know which capacitors for the vertical IC from the data sheet, simply replace them and vertical IC replaced but need to check that you have intact supply too.
Cheers,
Reply 15 of 23, by ArcadEd
Ok, that makes sense. Thank you.
Reply 16 of 23, by ArcadEd
I did like you suggested and found the fused resistor and it seems good. However, I found 2 blown resistors and diodes along the way. Plus a few caps that seem to have leaked.
Do you suggest replacing the LA7835 Vertical IC as well? Is there a pretty good chance it's fried?
Reply 17 of 23, by pentiumspeed
My wording meant required! Replace IC please and that both capacitors. 100uF 35V will be also bad.
And clean off these gunk too.
Cheers,
Reply 18 of 23, by ArcadEd
pentiumspeed wrote on 2021-12-21, 00:11:
Cheers,
OK, so I found a total of 3 bad resistors and 2 bad diodes. Along with 4 caps that showed signs of leaking..
I replaced and cleaned up everything, including the IC. I checked the schematics and followed tracing from the IC to look for any more problem areas. I even scanned over the board several times. Doesn't mean I didn't miss anything.
Got it all back together fired it up. I'm getting something now, but not there yet. First picture is what it looks like as soon as I turned it on (Hooked to a computer).
Second picture is after I adjusted the H.Hold some.
Colors are off (no Brown, Yellow on my laptop screen). You can faintly make out the icons in the second picture. I labeled all wires so I know where they came off (this is a way more complicated monitor than you typical Arcade monitor, sheesh).
Reply 19 of 23, by pentiumspeed
Progress! 😀
This looks like horizontal sync signal not making through properly or clean enough. Keep checking these components that was wet from the capacitor juice.
Cheers,
