First post, by JoelD
Hey Everyone,
Sorry if this is the wrong place to post this, if so just let me know and I'll move it (I'm new here).
I recently picked up an old Socket 7 Gateway 2000 machine for some classic windows/DOS gaming and it's been a lot of fun getting it working and upgrading it. It's so so close to what I want but I'm having some issues with the sound in DOS games. I picked up an SC-88vl for MIDI and that's been mind blowing but here's where the issue I have starts. The PC has an onboard Soundblaster Vibra 16 which works great for sound effects but it unfortunately has the hanging note bug when playing through the Sound Canvas (Also basically every game on the list of bugged games are ones I put this PC together for). I picked up a SoundBlaster Live! PCI card and stuck that in and it fixed the hanging note bug, the Sound Canvas now sounds amazing in Duke3d and Heretic etc. but after anywhere from 5-10 minutes into playing, the Live! card just flat out stops playing sound effects until I reboot, only in DOS mode, the Card still plays sounds in windows just fine. They just stop and don't start again until the computer restarts. I've gone into the Duke 3d setup after the sound drops and I get a DMA error using the exact same settings that worked before the sound dropped out. I've tried different PCI slots to no avail, different settings like mono vs stereo, different sample rates, different sound blaster options but the problem persists no matter what.
So my questions to y'all as an absolute noob here are:
1)Can I use the Live! Card for Midi only and the Onboard card for SFX? If so, I couldn't figure that out so any insight would be amazing (Windows DOS mode, not Pure DOS)
2)Is there any way to solve the Hanging Note bug?
3)Is the problem with the Live! card dropping sound common? Is there a solution?
4)Should I just buy a new Sound Card and if so which one would be best to use with the SC-88vl connected through gameport?
Other Info that might be helpful:
Windows 98se
Running games through Windows DOS, not big kid DOS
Voodoo 3 Also in a PCI slot (Overkill I know but it was cheaper than a 2)
Onboard Sound Disabled in BIOS when using Live! card
Losing sound in all DOS games with Live! (Duke 3d/Dark Forces/Chex Quest etc) Seemingly not game specific
Thanks in advance for any help anyone can bring to the table here. This has been a months endeavor and I feel like I'm almost at the end.
Reply 1 of 13, by Gmlb256
Hello! Welcome to VOGONS!
I will answer your four questions.
JoelD wrote on 2021-09-17, 02:18:
With both sound devices enabled the SB16 emulation for the SB Live! will be disabled. However, there's a way that will allow you to only get MIDI support on the SB Live! card for DOS games while keeping the SB16 Vibra for digitized sound effects.
NewRisingSun did release a workaround for that bug that plagues certain SB16 revisions. However I don't have any cards (including SB16 devices) that suffers from said bug and don't know if that works on Windows. There are also two types of hanging notes, which one much less frequent but can be annoying for some people.
I've heard issues with Build Engine based games when using the SB Live! Ken Silvermann did release a workaround for this. Check the section where it mentions the "echo" crash patch. Also make sure that you have the VXD drivers installed as by default it will install the WDM ones which has many problems.
Buying another ISA sound card is the best choice here. Getting an SB16 with the least amount of bugs (especially regarding the MPU-401) or a SB Pro compatible clone card with MPU-401 support are the only options in this case.
You can also get more information from the following link about the SB16 bugs: Sound Blaster 16 Bugs and Deficiencies Summary
Reply 2 of 13, by JoelD
Wow thanks for all the insanely helpful information! It's looking like picking up a new card might just be the best option here which really isn't a big deal that Live! card was cheap. It's also given me other problems like stuttering audio in certain windows games unless I turn hardware acceleration off, waiting literally an hour of the setup to complete each time I re-install windows, so I won't be sad to see it go. It might just be a little too new for the PC it's in. I'll do some more research and take a look on ebay to see what I can find. If you have any specific recommendations that would be awesome! Thanks again so much for all the help you listed!
Reply 3 of 13, by Joseph_Joestar
An ESS AudioDrive 1868F is cheap, readily available and doesn't suffer from any of the bugs that plague Creative's cards.
It will happily coexist with your Vibra as long as you ensure that both cards use different resources (address, IRQ, DMA etc).
Reply 4 of 13, by Gmlb256
JoelD wrote on 2021-09-17, 03:23:
You're welcome!
Some specific recommendations for a good ISA sound card:
- Like Joseph_Joestar said, the ESS AudioDrive ES1868F is a very cheap sound card and has good SB Pro compatibility. The FM synth on these cards are mostly faithful to the Yamaha OPL3.
- There's also the YMF-71x based sound cards with real Yamaha OPL3 FM synth. However they don't support an specific ADPCM format which only about two or three games uses it (most notably Duke Nukem II).
Both cards also supports MPU-401 for you Roland Sound Canvas device without any problems and WSS on Windows for 16-bit mixing.
Reply 5 of 13, by JoelD
Awesome, Thank you both so much! I'm just browsing Ebay for an ES1868F now. You were right, there's quite a few listings and they aren't expensive, just gotta pick the best looking with the fastest shipping times.
Reply 6 of 13, by JoelD
Found one with a CD Audio Connecter, listed as tested/working and wasn't covered in dust and was under $50. Thank you both again! Can't wait for this thing to show up!
Reply 7 of 13, by Joseph_Joestar
Here's a nice video review of the 1868F by Phil.
You might also want to get the DOS driver pack from here.
Reply 8 of 13, by JoelD
That's funny I just finished watching that video. I'll definitely grab that thanks for the link!
Reply 9 of 13, by Joseph_Joestar
One last thing to note. By default, Windows 98SE will install WDM drivers for the 1868F, which are suboptimal.
If you want to play DOS games from within Windows, grab the VxD drivers from Phil's website and install those manually. Specifically, you want the 185xw95.zip archive.
Reply 10 of 13, by JoelD
Ya I downloaded those and the DOS drivers he has after watching the video. I learned quickly after starting this PC his website is as useful as this one for finding old drivers, what an amazing dude. Should I go with 185xw95.zip or 189xw98.zip for windows 98? I had downloaded 189xw98.zip but if 185xw95.zip works better for any reason I can throw that in the folder instead.
Reply 11 of 13, by Joseph_Joestar
JoelD wrote on 2021-09-17, 06:50:
If I'm remembering correctly, the 185xw95.zip archive contains VxD drivers while 185xw98.zip contains WDM drivers.
You don't want WDM drivers for playing DOS games as they lack FM synth functionality.
Reply 12 of 13, by JoelD
Ok Sweet extra thanks for the heads up on that! I'll stick those in the folder for when the card shows up. I'm maybe even thinking of going Win 95 this time around, that's what came installed on this model when I was a kid, It's the same model as the first computer my family got when I was like 11, but upgraded in all the ways.
Reply 13 of 13, by Joseph_Joestar
JoelD wrote on 2021-09-18, 01:00:
Win95 is a solid choice for a Socket 7 system. I use it on my Pentium MMX rig, mostly for nostalgic reasons.
You might want to check out this thread: Windows 95 setup guide for the 2020's
