First post, by llm
static inline void send_control_or_mode_change_midi_msg(uint8_t channel_, uint8_t controller_nr_, uint8_t controller_value_)
//(channel_ <= 15)
//(controller_nr_ <= 119) ==> Control change
//(controller_nr_ > 119) ==> Channel mode message
send_midi_msg3(0xB0u + BITS4(channel_), BITS7(controller_nr_), BITS7(controller_value_));
these are hardcoded calls in the game that im reversing - im trying to figure out what the controller-nrs are and what the values or value-ranges are allowed
https://www.midi.org/specifications-old/item/ … of-midi-message
https://www.midi.org/specifications-old/item/ … es-data-bytes-2
https://nickfever.com/Music/midi-cc-list
send_control_or_mode_change_midi_msg(channel_, 0x7B /*123*/, 0); // Channel mode message --> All Notes Off?
send_control_or_mode_change_midi_msg(channel_, 0x79 /*121*/, 0); // Channel mode message --> Reset All Controllers?
send_control_or_mode_change_midi_msg(channel_, 0x07, velocity); // Control change --> Channel Volume (formerly Main Volume)?
send_control_or_mode_change_midi_msg(channel_, 0x0A, velocity); // Control change --> Pan?
send_control_or_mode_change_midi_msg(channel_, 0x01, velocity); // Control change --> Modulation Wheel or Lever?
