First post, by Sphere478
What’s the easiest way to verify cpu voltage? Can I set the voltage wothout a cpu installed, power it up and check it or should I install a higher voltage cpu and test it then install the lower voltage one?
Also how do I check voltage with a volt meter on socket 7? Do I have to test at the back of the socket or can I get it from the fet to ground? If so how?
Will core voltage be present at the jumper pins?
How does this all work?
I was thinking of firing it up without the cpu and using a volt meter on some pins I manually insert into the socket. But which pins should I check?
Sphere's PCB projects.
Reply 1 of 6, by brian105
The board very likely has jumpers on it which dictate the set voltage. On socket 7, it's anywhere from 2.5v to 3.5v. Look up details for your motherboard to see info on how the jumpers should be set for the voltage, or maybe you have a diagram silkscreened somewhere on the board.
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD
2007 Desktop: Athlon 64 X2 6000+, Asus M2v-MX SE, Foxconn 7950GT 512mb, 4GB DDR2 800, Audigy 2 ZS, WinME/XP
Reply 2 of 6, by Sphere478
brian105 wrote on 2021-01-20, 03:19:
I’m going to be using undocumented jumper settings which is the reason for this post. I’m aiming for 2v or less. But can settle as high as 2.2
Reply 3 of 6, by Deksor
Take a look at socket 7's schematic
I think the pin you want to measure is a VSS pin. There are many around the socket but one that's easy to find is the one near the "key" pin.
Reply 4 of 6, by Sphere478
Deksor wrote on 2021-01-20, 17:02:
Take a look at socket 7's schematic […]
Perhaps the one opposite of the flat corner is easier to be sure about cause the one by key flips with orientation
Vcc to ground to get reading?
Aren’t there two voltages? One for I/O and one for core? I need to check core yeah? Is that the vcc?
Reply 5 of 6, by quicknick
My preferred way is to stick a dual voltage chip that is 'high-voltage' tolerant, like a 6x86MX or first-gen K6 with the board set for a supported/known voltage. After powering on it's quite easy to find a measuring spot, usually it's the tab of one of the mosfets. After that it's safe to play around with jumpers, because a 2.9 or 3.2v chip shouldn't immediately destroy itself at 3.5v (and usually this voltage is among the marked ones so no need to go that high).
A good practice is to search for the datasheet of the PWM chip, in most cases this provides sufficient information (and sometimes closer to the truth than the board's silkscreen or manual).
Reply 6 of 6, by Sphere478
quicknick wrote on 2021-01-20, 21:36:
The top tab? The one that sometimes has a hole for screwing to a heatsink?
Sounds like a good method thanks
So if there are two fets one is I/O and other is core?
