First post, by wanderyr
Nothing seems to happen when I enable the nullmodem server in the config file. I'm running an Ubuntu 18.04.5 system with DOSBox v0.74-4.3 (this is the ubuntu package version). I expect to see "Nullmodem server waiting for connection on port 23..." in the console but it never appears. Otherwise DOSBox works just fine.
dosbox-0.74.conf:
[serial]
serial1=nullmodem
from console:
CONFIG: Loading primary settings from config file {correct file path}
MIXER: Got different values from SDL: freq 44100, blocksize 512
ALSA: Can't subscribe to MIDI port (65:0) nor (17:0)
MIDI:Opened device:none
(nothing else!)
I suspect it may be a permissions problem. Does the linux user need to be a member of any specific group?
I'm not looking for help with the midi issues; I just include them here in case it helps with troubleshooting.
Is there any other information that would help?
Thanks very much for all of your time. DOSBox is great 😀
Reply 1 of 2, by _Rob
The lower 1024 ports are restricted on Unix (and hence Linux) to root. A regular user cannot use them.
For the nullmodem server, specify something like:
serial1 nullmodem port:5000
For the client, you then specify:
serial1 nullmodem server:<IP or hostname of server> port:5000
Reply 2 of 2, by wanderyr
_Rob wrote on 2020-11-11, 21:17:
That was it, Rob! Thank you very much.
