First post, by plattertough
Hi, first time poster and also first time building a Windows 98SE machine. I'm pretty new to this stuff so really any solution is on the table. My setuup:
ASUS PV3133
Intel P3 550 MHz
256MB*2 SDRAM PC133
Matrox Millennium G400 16MB AGP
YMF724F
Corsair RM550X (does not have -5V rail)
After getting my graphics card drivers working (wouldn't until I installed VIA 4-in-1 drivers), I tested everything using Quake 2. Game runs fine for a few minutes and then crashes the whole system. Even the 3D Pipes screensaver crashes the system after too much has drawn. Running in software works fine. Same issue when sound card is removed. I rolled back the Matrox drivers to the oldest I could find on this site - the game now lasts a lot longer but eventually flashes the illegal operation message and crashes. Any advice on what could be going wrong?
Reply 1 of 6, by skitters
My guess is heat.
Since that Matrox card doesn't seem to have a fan, make sure there's plenty of extra air circulation in the computer case.
Reply 2 of 6, by Con 2 botones
plattertough wrote on 2020-10-21, 21:46:
Hi, first time poster and also first time building a Windows 98SE machine. I'm pretty new to this stuff so really any solution i […]
ASUS PV3133
Intel P3 550 MHz
256MB*2 SDRAM PC133
YMF724F
I first thought too that your issue was related to overheating, as "skitters" stated. Although, since changing the video drivers makes the situation a little better, it might not be a hardware issue then, but software.
Do you happen to have another video card around to try?
Also, I could not find any information about that Asus PV3133 board. Are you certain that´s the correct model?
Related to the previous, what version of Via chipset drivers are you using?
Reply 3 of 6, by swaaye
Moved the thread over to Marvin/Video.
VIA AGP instability may be the problem. If it's running AGP 2x-4x, see if you can force the card to AGP 1x by the system BIOS. Otherwise get the Matrox Technical Support Tweak Utility and force it to 1x.
https://ftp.matrox.com/pub/mga/utils/tech_sup/2002/
Also which G400 driver release are you using? Are you using TurboGL? I think I would try drivers between Powerdesk 5.41 and 6.21. The earlier drivers include TurboGL, which is a highly optimized miniGL for Quake based games. In the Powerdesk 6.xx series the regular OpenGL ICD replaces TurboGL and is about the same speed.
https://ftp.matrox.com/pub/mga/archive/win_9x/2000/
Reply 4 of 6, by The Serpent Rider
You can force specific AGP speed, sideband adressing and fast writes by RivaTuner on any card BTW.
Reply 5 of 6, by Dmetsys
Have you re-pasted the GPU before you tested it? 21 years on stock TIM pads isn't something I'd recommend. Wouldn't hurt to install a 40mm fan on the heatsink as well, for additional cooling.
NF7-S 2.0 | 2500+ @ 3200+ | 2GB OCZ Platinum 3200 | 9700 Pro | Audigy2 ZS | XP Pro SP3
CUV4X 1.03 | PIII-933 | 256MB PC133 | MX400 | Live! Value 4670 | 98SE
4DPS | Am5x86-P75 | 32MB FPM | MGA Millennium 2MB | SB16 CT2290 | DOS 6.22
Reply 6 of 6, by PC Hoarder Patrol
Assume it's the Asus P3V133
https://dlcdnets.asus.com/pub/ASUS/mb/slot1/p … /p3v133-102.pdf
As there were only a few bios versions for this board, are you on the latest (P3V133 Beta BIOS 1003.002 7/8/02)
https://dlcdnets.asus.com/pub/ASUS/beta/mb/bios/pv133132.zip
Also, be worth checking for failing capacitors.
