First post, by GigAHerZ
Windows 95 and 98 have their built in "Microsoft Sythesizer", that's being used for midi music playback with windows media player.
But we all know that soundcards themselves can also sythesize midi sounds. (And this is the default with, let's say, Windows 3.11)
When i go to "dxdiag" utility and look under "Music" tab, it shows all available MIDI outputs and lets you to even play a piece of music with your choice of synthesizer.
The utility looks like this (picture from the internet): https://duncanbowring.files.wordpress.com/201 … 49-am.png?w=632
Is there any way i could swith over to native sound card's sythesizer instead of Microsoft Synthesizer from somewhere? I can not find a place to modify the "Default Port" option anywhere in Windows at all.
Any suggestions where to look?
Reply 1 of 6, by derSammler
Control Panel -> Multimedia -> MIDI
Reply 2 of 6, by GigAHerZ
Thanks @derSammler,
Interestingly, that window location you suggested, does not have Microsoft Synthesizer. It only has "Creative Music Synth [220]" and "SB16 MIDI Out [330]".
I just did set up the windows again and what's also curious now is that Media Player now seems to be using only the soundcard's synth and only way for me to hear the "beautiful" Microsoft Sythesizer is to test the Music playback in "dxdiag".
Microsoft Synthesizer is still marked as the "Default Port".
What have i touched without me knowing about it? A bit confused now...
Reply 3 of 6, by Falcosoft
GigAHerZ wrote on 2020-05-28, 09:40:
Thanks @derSammler, […]
Thanks @derSammler,
There are 2 different MIDI related API available in Windows 9x. The classic WInMM and Directmusic. The Microsoft GM/GS Softsynth is only available as classic WinMM Midi Out port when you use WDM drivers. With Vxd drivers The Microsoft GM/GS Softsynth is only available as a Directmusic device (listed as Microsoft Synthesizer). On the control panel Multimedia -> MIDI part you can select what is the default Midi Out port for applications using WinMM API while in Dxdiag you can test Directmusic API. The vast majority of Win32 Midi applications use the classic WinMM API. WMP is an exception.
Ps:
On modern x64 Windows DirectMusic is virtually dead (despite it was later than WinMM) since some part of it has never been implemented for 64-bit.
WinMM API is still fully functional even for 64-bit applications (the missing Midi mapper is another issue).
Website, Facebook, Youtube
VST Midi Driver Midi Mapper
Reply 4 of 6, by GigAHerZ
As i understand then, under Multimedia -> MIDI, i should have an option of "Microsoft GM/GS Softsynth".
I currently don't have it there. I tried adding new hardware and install manually all kinds of microsoft's soft synths that are available for windows, but nothing created me a new option in the "MIDI" tab of Multimedia Properties.
How can i get that Microsoft's soft synth available in the MIDI tab?
EDIT:
Microsoft Synthesizer in Windows 9x
From here i read that this MS's synth is not installed by default, if sound card can be synth on it's own. But can i still manually add MS's synth so i can choose which i want later?
Reply 5 of 6, by Falcosoft
GigAHerZ wrote on 2020-05-28, 12:17:
No. You only should have Microsoft GM/GS Soft synth as normal Midi Out port if you have WDM drivers installed. By default SB16 setup installs the Vxd drivers. With Vxd drivers installed you should NOT have Microsoft GM/GS Soft synth listed as possible Midi Out port.
(Look at your driver in device manager. You most likely have 'Sound Blaster 16 or AWE32 or compatible' under Sound Video and Game controllers. If you look at your driver file properties you most likely find SB16.VXD among others. This means you have VXD driver installed. To tell you the truth I'm not even sure if WDM drivers exist for SB16.)
Install WDM drivers for your soundcard (if available). WDM drivers are only supported in Win98+. Win95 can only use Vxd drivers.
(Among ISA cards ESS1868/1869 definitely has WDM drivers. Creative PCI cards (Live/Audigy) also have WDM drivers. )
This is simply not true. It is always installed as part of Directx/Directmusic. Availability as a Midi Out port depends on the driver model not the synth capability of the soundcard.
(Otherwise if it would not be "installed" you could not see it in Music tab of Dxdiag either. And as you can see there it is.)
As confirmed by MS:
https://support.microsoft.com/en-ca/help/1932 … etable-sw-synth
... Note that the Microsoft GS Wavetable SW Synth device is available for use in Windows 98 only when Windows Driver Model (WDM) audio drivers are being used.
Reply 6 of 6, by GigAHerZ
@Falcosoft, thanks for that information! The windows detected my Vibra16 card automatically as "Creative Sound Blaster 16 Plug and Play", quite possibly it's VxD. (How to check it? Though, it shows it's from 1997, therefore pre-Win98, so quite certain, it's VxD)
I've looked around, that with WDM, usually you need to sacrifice some performance - the slower cpu, the more performance you loose. Considering that, i'm not so keen to have Microsoft's Synth freely selectable anymore, if i loose some performance on my Pentium MMX @266MHz. 😜
Thank you once again for clarifying this issue! I may try WDM driver out (if i find one) just to confirm this on my hardware as well. Thanks again!
EDIT: Found "Driver File Details" window in Device Manager, which shows "SB16.VXD" as one of the driver files, while there are no ".WDM" files mentioned.
