Full screen
First post, by Darenwhite
I have wordperfect 5 which I can get to work using DOSBox on my windows 10 pc. The problem I have is getting it to run in full screen with no borders around. It used to run in 800x600 mode on windows xp. Is there also a way to have DOSBox close when the wp command is loaded?
Reply 1 of 2, by Jorpho
If you want to run apps like WordPerfect, you would probably be better off using vDosPlus. There is an immense knowledgebase on the subject available at http://www.columbia.edu/~em36/wpdos/ .
Reply 2 of 2, by IIGS_User
Darenwhite wrote on 2020-05-18, 13:24:
Exiting DOSBox will also exit any game that is executed within.
Klimawandel.
