First post, by Fortesquedaniel
So I got this pretty rare multimedia PC (MXS10 model).
I managed to fix all of it's hardware problems (yes, MD drive is not the hardest part to fix. zero rubber belts and cheaply available KMS-262E laser module on Aliexpress)
But I can't defeat the software side.
As I suddenly realized, Sony completely removed every piece of driver/software for everything which is not compatible with Windows 8 and higher. They even stopped sending retail recovery CD-Roms by request.
Now the only way to get this piece of history to work is wiretap's Acronis HDD image.
wiretap wrote on 2018-06-18, 03:37:In the meanwhile, I snapped an Acronis image of the system in its OEM state. https://archive.org/details/PCVMXS20DiskImage.7z
But there are some problems.
First boot works like a charm. But then LCD and front panel buttons behave like there are no drivers installed.
As I understood, this PC's multimedia stuff is built over a custom PCB, connected to the Asus P4B-LX mb via USB bus.
Front panel LCD display and buttons are connected to this PCB and with the Audio board (20W amplifier with RCA and Toslink out/in) this combination called "Sony Turn Pike".
Before Windows boots and USB driver kicks in, LCD screen is showing animated MX logo and HDD/CD usage as standard LED's on every PC case.
wiretap's acronis image was made on MXS20 - which is the same PC but with slightly higher PC specs (ram/cpu freq) AND as I found out with a different PCI dialup modem.
Why is that important? Because in MXS1 /10 PCI dialup modem board also has Ricoh PCMCIA controller, connected to the same custom Sony PCB (usb-front panel LCD-audio) via proprietary connector. So basically the PCI part of this modem board is a PCMCIA controller. And the modem is just a USB device, soldered to the same board.
I tried to completely remove dialup modem. Everything works fine but the issue with LCD driver is still there.
I'm looking for some help to figure out what the hell is wrong with these USB drivers or maybe someone still has retail CD-roms...
