First post, by MiniMax
Rank Moderator
Moderator
DOSBoxWiki is a collaborative guide to DOSBox - written by the DOSBox users themselves. Read it here.
The guide is a work-in-progress guide, meaning that it will never be complete and finished. As DOSBox develops, so do the DOSBoxWiki.
If you see something is wrong, even something simple as a misspelled word, you have the power to edit the page, and correct the problem.
If you think something is missing, go right ahead and either insert the text into an existing page, or add a completely new page to the guide.
_________________
Editing, adding, and formatting Wiki-text is really easy. Headings are created by surround the text with '=' markers. One '=' for top-level headings, two for normal headings, and three for sub-headings:
= Top level heading =
== Normal heading ==
=== Sub heading ===
becomes
Top level heading
Normal heading
Sub heading
_________________
Fonts are also easy to change:
''italic text'' (two single quotes) becomes italic text
'''bold text''' (three single quotes) becomes bold text
_________________
Lists are created with *'s and #'s:
* First bullet
* Second bullet
* Third bullet
# Item 1
# Item 2
# Item 3
becomes
  • First bullet
  • Second bullet
  • Third bullet
  1. Item 1
  2. Item 2
  3. Item 3
_________________
If you want to practise you Wiki-skills before making changes to the DOSBoxWiki, go right ahead and scribble something in the sandbox.
The full list of formatting rules are available at the WikkiTikkiTavi site.
_________________
