First post, by sonicexenia
Good evening everyone's health;
After many many attempts and tests I managed, even if not totally, to use the Xtide ite V.4 on my Olivetti M24, bios V.1.36;
I also enclose the video link.
https://www.youtube.com/watch?v=1i-UXczRTX8
As you will see, at a normal start, in the Boot phase of the CF in Xtide,
there is in the Xtide menu an exchange between C>> HDD [C] to D>> HDD [C].
Then the famous error 1h appears! and boot into A:
In this case if I try to enter the Cf, with C: it gives me a reading error, but the unit exists.
If instead, at the start, when the Xtide Menu appears, I press the D key on the keyboard
from C>> HDD [C] changes to D>> HDD [D] and everything works,
boot from Cf on Xtide lt, and CF is detected as C:
But I don't understand why the Xtide bios can't do this automatism,
without me having to press the D button.
I've tried various formatting, also done Fdisk MBR, but without solving.
Reply 1 of 8, by jesolo
Cannot quite make out but, do you have a hard drive (MFM) controller still installed in your M24? In other words, was there previously a hard drive in that computer?
If so, unplug that controller and set you XT-IDE to address C800h.
Then, boot up with a DOS boot disk and type in FDISK /mbr (ensure that FDISK is on the boot disk).
Reboot again (without the boot disk in drive A:) and see what happens.
Reply 2 of 8, by sonicexenia
jesolo wrote:
Cannot quite make out but, do you have a hard drive (MFM) controller still installed in your M24? In other words, was there pre […]
Hi, thanks.
I have two xtide, a Normal and a LIte.
I have the identic problem with both.
See the new video.
https://youtu.be/ijhY5chdYS8
In first moment i have start M24 without press key on keyboard.
Xtide is at C800h Address.
Don't boot at Xtide but only with A:
I have used Fdisk /Mbr command but without resolved problem
In second moment,
i have start M24 and press D (??)
M24 boot correctly with Xtide at drive C:
I press D and boot C: .... why ???
I have another M24, model Sp and the problem is the same
Thank very mutch
Reply 3 of 8, by sonicexenia
I have resolved!
My m24 have two floppy Drive.
Floppy drive B have a conflict with Xtide.
I HAVE disable Floppy Drive B, via Dip Switch on Motherboard, and the problem is solved.
Thanks
Reply 4 of 8, by Caluser2000
Thanks for letting us know it's sorted. I'm sure it will aid others in the future.
Reply 5 of 8, by Smurfswacker
Sonicexenia, if you're still out there, can you please look at my post:
Olivetti M24 and XT-IDE
I'm having problems getting my M24 to recognize an XT-IDE card. I thought you might know what I need to do. Thanks.
Reply 6 of 8, by 1ST1
I don't think it's the floppy.
The attachment cap1.pdf is no longer available
Reply 7 of 8, by sonicexenia
Se non vede il menù del BIOS della xtide di solito sono errati i dip switch sulla stessa.
If you do not see the xtide BIOS menu, the dip switches on the same are usually incorrect.
Reply 8 of 8, by sonicexenia
The attachment Screenshot_20200205-081700.jpg is no longer available
