First post, by aries-mu
Hi guys, it's incredible!
This is one of those times when computers seem to act on purpose to drive you nuts!
So I have this 512MB SD Card, bootable, FAT-16, which I use as HDD under MS-DOS 6.22 via IDE to SD card adapter, all good.
I loaded this card in the past using my Core i3 Win10 laptop, countless times.
Now I'm not able to copy anything anymore on the SD card using my Win10 laptop! INCREDIBLE!
I can't even create a folder. If I right-click there is no "create new..." voice in the drop menu!
If I try to copy anything it says that it is write protected, oh but the write protection physical switch on the SD card is very well unlocked! And under MS-DOS it writes perfectly.
There was no way to un-protect this SD Card, not even using the diskpart utility.
Is this normal or what?
Thanks guys!
They said therefore to him: Who are you?
Jesus said to them: The beginning, who also speak unto you
Computers should be fun inside not outside! 😉 (by Joakim)
