First post, by haker120
I have Aureal Vortex 2 sound card. I am aware it's not perfect solution for DOS gaming but I need to set volume in DOS mode for DOS games that don't work on my clean DOS setup. I have file au30mix.exe on HDD and seems it does work (including message to ask here for help xD) but I have no idea how to set it up. In few games like Doom 1 and 2 I have all, sound and music, in Rayman I have only sounds, no backround music and I bet it's mute in configurator. How to do it?
Reply 1 of 8, by badmojo
The Vortex2 makes a really good DOS sound card IMHO - good SB Pro compatibly and a working wavetable header (which needs to be populated because the FM synth is horrid!).
The lack of a mixer was a problem for me too until this happened:
Release -New Aureal DOS Mixer Util-
Reply 2 of 8, by haker120
Thank you so much, I need to try it! And that's a reason I did choose AV2, maybe it's not the best option for DOS but indeed it is for PCI plus DOS, will DreamBlaster S2 help with quality?
Reply 4 of 8, by haker120
Actually I want to order this. 😀 http://www.serdashop.com/waveblaster. And well, DOS games that don't have CDDA work louder, with games like Monkey Island, Rayman I have sound effects but a lack of background music, CD is in drive (original games), audio cable connected correctly. How to fix it?
Reply 5 of 8, by badmojo
Could be a mixer issue I guess?
Reply 6 of 8, by haker120
Probably, I got four zeros when I put au30mix.exe in CD audio line.
Reply 7 of 8, by ZanQuance
4 zeros means the gain is at maximum already
Reply 8 of 8, by haker120
So, why doesn't it work?
