Graphics card choice for 486 DX4-100 system
First post, by Godlike
Hello everyone
I recently acquired one of late socket 3 motherboards. Motherboard comes with AMD DX4-100Mhz CPU.
My plan is to build MS-DOS 6.22 or WIndows 3.11 system.
I'm not sure what brand of this motherboard is, what manufacturer made it at all.
2A0Negt.jpg?1
I will be grateful if someone could help me identify this motherboard
ASUS P2B-F, PII 450Mhz, 128MB-SDR, 3Dfx Diamond Monster 3D II SLI, Matrox Millennium II AGP, Diamond Monster Sound MX300
Reply 1 of 26, by Jade Falcon
Rank BANNED
BANNED
ATI match 32 or 64. Maybe a s3 virge? or trio?
That's my picks.
Reply 2 of 26, by clueless1
If you don't care about period correctness, the TNT2 M64 PCI is one of the fastest in DOS games, and very compatible with the era of games you'd be playing. Other fast, compatible PCI options are S3 Virge/DX/GX, and CL-GD5446. Another fast, non-period-correct option is Voodoo3 or Banshee PCI.
If you intend to do Win3.1, keep in mind that the newer cards probably won't have Win3.1 drivers.
Reply 3 of 26, by Godlike
Here's the selection of graphics I mentioned for this system:
ATI Mach64 ISA
7t5YKQ5.jpg?1
Diamond Stealth 64 DRAM PCI (S3 Trio64)
Diamond Stealth VRAM ISA (first card of Diamond Stealth line I presume)
Matrox Ultima PCI (IS-ATLAS R1)
Reply 4 of 26, by Godlike
I am condemned to choose between thos graphics, I'm affraid.
This must be graphics supported in MS DOS of course, better to stick with that era period. No big difference like Voodoo 3.
I have to choose between this four graphics as I have no other close to that era.
What would you suggest and why?
Will be nice to pick graphics that have support for various MS-DOS games and other multimedia stuff
EDIT: Diamond Stealth VRAM ISA looks nice to me.
What is most valuable card in this collection?
What do you think?
Reply 5 of 26, by clueless1
Trio64 is the best choice IMO. You want PCI, and between that and the Matrox Ultima, the S3 is faster and more compatible.
Reply 6 of 26, by Godlike
Both cards are equipped with S3 chip, both from Diamond Multimedia. What about Stealth VRAM? I heard that MS-DOS likes VRAM, Windows like DRAM
Reply 7 of 26, by clueless1
The PCI version is the one you want. Not the ISA. The increase in bus speed will more than offset any difference between VRAM and DRAM.
Reply 8 of 26, by Nvm1
It's a beauty that motherboard, made by Intel judging by the Lay-out. Photo is a bit unsharp to see all details (prints on the chips etc).
For a Graphics card my choice would be the PCI S3, like clueless said it will blow away the ISA cards who are hampered by the ISA bus limit.
If you may find a cheap isa Cirrus Logic then that is a good choice too seeing how compatible they are overall. 😀
Reply 9 of 26, by jade_angel
Another decent choice, if you can find one, might be a PCI Rage 128 or Radeon (Standard, DDR, 7500 or VE, probably not a later one), though you may have difficulty finding drivers for Win3.1 or OS/2. IIRC, Matrox made a PCI G400 also, which might be a good call, though apparently the G400 has some weirdnesses in some DOS games (Commander Keen?)
Of the cards you showed, the PCI S3 Trio would be my top choice by far. PCI > ISA for graphics, unless you're comparing a screamer of an ISA chip (ET4000, etc) against a stinkerino of a PCI chip (Trident 9680, say), and even then, the PCI card might still have the edge.
Main Box: Macbook Pro M2 Max
Alas, I'm down to emulation.
Reply 10 of 26, by Godlike
Actually, I realise that cards are from years:
Matrox Ultima-> 1993
S3 Diamond Stealth64 PCI -> 1994
ATI Mach64 ISA 1994
Diamond Stealth VRAM ISA 1992
I would be correct to choose Diamond Stealth (S3 Trio64) as you wrote, DX4 CPU have been released in 1994 too.
Let me do some more hires pictures of motherboard itself
Reply 11 of 26, by brostenen
My personal picks for a system such as that are:
- S3 Trio64v+
- Cirrus Logic 5446
- S3 Virge 325
All with at least 2mb of ram. Nice board by the way. Never seen a layout quite like that.
EDIT:
Love the layout even more. You can have at least 1 full length PCI and 3 ull length ISA cards
in a system, using that board.
Reply 12 of 26, by TheMobRules
Go with the PCI S3. The improvement of PCI over ISA alone is going to be more significant than any other thing in this case. The DRAM vs VRAM thing doesn't really matter too much. Besides, if I remember correctly DRAM performs slightly better than VRAM in DOS (while the opposite holds true for Windows).
Maybe the Matrox could be a good option too, but you're definitely going to have less compatibility issues with the S3.
EDIT: interesting board you got there. The Intel chipset (not that common in the 486 era) and the auxiliary PCI power connector lead me to think that it may be an Intel board, maybe made for some OEM.
Reply 13 of 26, by brostenen
And do not forget, that a lot of ISA cards, produce vertical spaghetti lines on a TFT screen.
This however is not really an issue on CRT screens. Or using PCI cards on a TFT.
Out of all PCI cards that I have tried and tested, I had only had issues with an CL-5440 on TFT screens.
Another good advice is to check the VGA compatibility chart, as mentioned so many times before.
Reply 14 of 26, by Godlike
brostenen wrote:
And do not forget, that a lot of ISA cards, produce vertical spaghetti lines on a TFT screen. This however is not really an issu […]
Hehe spaghetti:) I got with Matrox on TFT, I know what you mean, other cards are fine 😀
High resolution pictures of the motherboard comming very soon!
Reply 15 of 26, by Godlike
front layout of the motherboard:
http://imgur.com/Jb18hpL
and back of the motherboard:
http://imgur.com/Ul6wEC6
Edit: I don't know wat is manufacturer of this motherboard. Looks nice to me too, look at the photos again you will find sort of blue wires. I'm not sure what's this, kind of modifications, or motherboard have been fixed?
Edit2: I also plan to put Mozart Wave-Table ISA audio card with true Yamaha OPL 😀
Like here :
Reply 16 of 26, by dondiego
Are you seriously comparing a isa card to a 64 bit pci card like that trident? (even when that chip usually came with 32 bit dram).
The s3 trio64 would be my choice as well (obviously).
LZDoom, ZDoom32, ZDoom LE
RUDE (Doom)
Romero's Heresy II (Heretic)
Reply 17 of 26, by kixs
Definitely go for PCI card. Those ISA cards are high end but for 386 or 486 ISA only systems.
Visit my AmiBay items for sale (updated: 2025-03-14). I also take requests 😉
Reply 18 of 26, by Godlike
I will go with s3 trio64 then, I realised that is best choice from all cards I have
Reply 19 of 26, by Tetrium
Is this your board?
Nvm1 wrote:
It's a beauty that motherboard alright, made by Intel judging by the Lay-out. Photo is a bit unsharp to see all details (prints on the chips etc).
Looks like an Intel board, looking at the pacement of the ISA and PCI slots.
My retro rigs (old topic)
Report spammers here!
