Duke Nukem 2 ADPCM fix?
First post, by Cyberdyne
I extracted the SB_x.MNI files from NUKEM2.CMP.
But now i need a comverter that can convert Sound Blaster ADPCM VOC files to Uncompressed PCM VOC files.
Can somebody help me. This conversion should fix OPL-SAx and other Clone card issues.
Or maybe someone has allready done such a conversion.
Reply 1 of 36, by dr.zeissler
What is the goal of this?
Reply 2 of 36, by PhilsComputerLab
Reply 3 of 36, by Cyberdyne
SB_x.MNI files are standard Sound Blaster VOC files, and few of them are compressed with Sound Blaster 8-2 or 8-3 ADPCM codec, but Duke Nukem 2 can play 8-4 ADPCM and uncompressed PCM files also. So you just have to convert them, and then leave those converted files in Duke Nukem 2 directory, and it will use them. The point is that Yamaha OPL-SAx do not play 8-2 and 8-3 ADPCM files in hardware, but Duke Nukem 2 is one of few games that relies on full Sound Blaster hardware decompression.
Reply 4 of 36, by psychz
I believe old versions of Cool Edit are able to open SB ADPCM .VOC files, might be able to save as uncompressed. Why don't you give it a try?
Stojke wrote:
Reply 5 of 36, by GuyTechie
Nice idea/ I didn't realize they were VOC files. Does the freeware Audacity work, too?
Reply 6 of 36, by leileilol
no. audacity doesn't even have the ability to save 8-bit files let alone VOC files
long live PCem
Debian's fucked
Reply 7 of 36, by Cyberdyne
I ask and I answer, i used Blaster Master 6.2, it is a dos sound program. Only it can not open 3 files, i think because they are too small, but those files are not compressed, Because Audacity does open them, and plays them. These files are SB_17.MNI SB_19.MNI and SB_22.MNI. All else i converted and uncompressed. Now everithing woks with external files, now i am trying to incorporate the new files to NUKEM2.CMP.
Reply 8 of 36, by PhilsComputerLab
I just like to say that you're doing great work and it is very much appreciated!
Reply 9 of 36, by Cyberdyne
Well i am a fan on Duke Nukem 2, and i do have 4xOPL-SA3 (3 of them with wavetable headers, and they do not have a hanging note bug) based sound cards, so i just started doing things.
Reply 10 of 36, by Cyberdyne
Do any other game have that same ADPCM (2-8) (3-8) sound output issue?
Reply 12 of 36, by simbin
Wow just wow, I can't wait for this! Didn't even realize it was a thing until I tried playing my beloved Duke Nukem 2 on newer hardware.
WIP: 486DX2/66, 16MB FastPage RAM, TsengLabs ET4000 VLB
Check out my Retro-Ghetto build (2016 Update) 😀
Commodore 128D, iBook G3 "Clamshell"
3DO M2, Genesis, Saturn, Dreamcast, NES, SNES, N64, GBC
Reply 14 of 36, by Cyberdyne
Yes, my work computer does not allow to install new software, but i got a portable dosbox, and portable Duke2Edit, but no portable Camoto, so i e-mailed my project files to myself, and if i have time in home, then i will try to repack NUKEM2.CMP.
Reply 15 of 36, by Cyberdyne
Put these files inside archive to your duke nukem 2 directory, and try for yourself, feedback appreaciated.
Reply 16 of 36, by Stretch
I extracted the files into the Duke Nukem 2 directory, but I do not get any audio output.
I use Dosbox Megabuild6 in Win98SE for hardware OPL output on a Yamaha YMF-744.
Duke Nukem 2 will not allow me to enable soundblaster or adlib with oplmode=hardware in the dosbox config.
The Duke Nukem 2 I am using is from GOG.
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - ESI Maya22 USB
Reply 17 of 36, by Cyberdyne
I am not familiar with that kind of a setup, but in a real PC with OPL-SAx, originally you get sound effects, but only few of them, but with these files, you get all sounds.
Reply 18 of 36, by keropi
I'll give it a go on my 386 that uses a SW20-PC, it's crystal based
🎵 🎧 SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 19 of 36, by GuyTechie
Thanks for this! I'm going to try it out when I get home. As you may know, I have one of the Yamaha Audacian Plus 32.
Should I try this with disabling L1 cache, or just leave everything full speed? I know disabling L1 cache did fix the sound issue at the intro, but not all sounds were still playing in-game. Also disabling L1 cache is too slow for actual game play. Disabling L2 cache doesn't fix the intro sound issue either. (PII-400 and P3-650).
