First post, by BSA Starfire
- Oldbie
Hi All,
My current interest has been with the second tier budget socket 7 chips, the Cyrix 6x86, L, MX, MII and IDT Winchip, the Winchip just does not seem to be at all picky what board it goes into, even old socket 5 seems fine, it's a pretty simple chip so that makes sense. However I have read that some chipsets have optimisation for the Cyrix, Linear burst mode to be specific, anyone know what chipset supports this and does it make much difference? I have seen varying reports, from 2%-10%, either way it might be cool to give the 6x86's a boost. Also is this only for the MX/MII or also the regualar vanilla 6x86?
My current Socket 7 chipsets are two Intel TX DFi boards, one AT one ATX and a MSi ALi Aladdin 5. I do have a SiS ECS P5SD-AS Socket 7 ATX board on route, I think that is based on the SiS 5591 chipset. Anyone know if these have the linear burst mode?
On a secondary point, I have found and use the 6x86 optimiser program from http://www.helsinki.fi/~mpjohans/6x86opt/ it seems to work well but is a bit above my level or understanding to be honest, anyone care to share then correct settings I should use for a DOS based 6x86 MX200 with 2mb ViRGE 325 on the Intel TX? Or are the defaults enough?
Finally is there any optimisation software like this for the IDT Winchip? Does it prefer any special settings?
Thanks,
Chris
