First post, by kithylin
Well I've been trying to come up with something that I could contribute to this wonderful community here, and I've been looking for something myself and after a very long time searching, I have finally come up with something, and thought I'd share it!
Now.. these drivers I've found, actually do claim to be for "3Dfx Velocity 100/200", however I have run the installer on my AthlonXP machine running windows 3.11, and it has an auto-detection mechanism built in to it, and some how my Voodoo3 3000 card was detected successfully under the "3Dfx Velocity 100/200" label, and it allowed me to set the higher video modes.
I've then rebooted and verified that indeed, these drivers do allow up to 1024x768 mode on a Voodoo3 3000 AGP card @ 65k colors.
I've also run "3D Ultra Pinball" game, which detects and can switch to 64k color mode, and it runs perfectly fine and works great.
So there ya go, windows 3.1 drivers for voodoo3. 😀
http://www.outfoxed.net/wfw/3DFX-WFW.DOS.rar
And the other part of this post. I do not see any drivers in the "VOGONS Vintage Driver Library" for early #9 / Number Nine video cards. I had actually last year bought a Number Nine 2MB #9GXE64 VLB card from a local used store, apparently it had been on the shelf since new and just never sold. It was way in the back, the price fell off the box, and I took it to a counter, they stuck $15.99 on it and I grabbed it. I used it for a while to make sure it worked in my 486 (And it was very fast!) but then I turned around and sold it for about $150 and bought a brand new in box PARADISE 1MB (Expandable!) VLB card for my 486 for $25. The reason I'm saying all this is before I sold the #9 video card, I took the time to duplicate the original Windows 3.11 drivers floppy diskette.
And now I've imaged that in to a WinImage *.IMA file and here it is online for everyone else to have.
http://www.outfoxed.net/wfw/%239GXE.ima
Enjoy, upload where ever you want, re-distribute where ever you want, I don't care.
edit: fix typos
Reply 1 of 11, by Stiletto
kithylin wrote:
Well I've been trying to come up with something that I could contribute to this wonderful community here, and I've been looking […]
Nice! Those came from Aquanox in 2010.
http://www.3dfxzone.it/enboard/topic.asp?TOPIC_ID=15868
http://www.falconfly.de/voodoo3.htm
Still, good find! 😀
do the Fandango!" - Queen
Stiletto
Reply 2 of 11, by kithylin
I couldn't remember where I had found them in the past as my main file server died a few months back and I lost all my old computer software and documentations. And then I found them in a folder on my AthlonXP machine, and didn't know where they came from so thought I'd share em anyway.
And I wasn't sure if it was obvious to others that they worked on a Voodoo3 3000, so thought I'd document that, too.
Reply 3 of 11, by Stiletto
No worries, man! 😁
Stiletto
Reply 4 of 11, by elianda
For #9 drivers you can have a look at ftp://78.46.141.148/driver/NumberNine/
Youtube Channel
Reply 5 of 11, by sliderider
Excellent. I needed the latest drivers for my Revolution3D and Revolution IV. I'm guessing that a generic S3 driver would work with their S3 boards?
Reply 7 of 11, by RX9
There appears to be a file missing from the archive that would allow access to 32 bit color. The "readme" notes refers to a third color depth driver, 3fxhv332.exe. Does anyone have this file from another source?
Reply 8 of 11, by Sedrosken
Is there a similar driver that will work for the Banshee? Because from what I'm reading this won't work for a Banshee, which is odd when under Everest my Banshee identifies as a Voodoo3 SDRAM with only one TMU.
Shoushi: Dimension 9200, QX6700, 8GB D2-800CL5, K2200, SB0730, 1TB SSD, XP/7
Kara: K7S5A Pro, NX1750, 512MB DDR-286CL2, Ti4200, AU8830, 64GB SD2IDE, 98SE (Kex)
Cragstone: Alaris Cougar, 486BL2-66, 16MB, GD5428, CT2800, 16GB SD2IDE, 95CNOIE
Reply 9 of 11, by vico
Do you know if with these drivers you can establish a resolution of 1280x1024 with 64k colors in a voodoo3?
Reply 10 of 11, by fosterwj03
The driver files contain a very interesting looking .INI file to define monitor support (3FXMON.INI). It includes VESA 1280x1024 at 75 and 72 Hz. It also includes some odd resolutions like 864x1200 and 2000x1500.
I wonder if you could modify that file to force Windows 3.11 into a widescreen mode such as 720p or 1080p at the correct aspect ratio. I wish I had a 3DFX card to test.
The 3FXMODE.INI file includes a 32-bit color option as well as video memory size options up to 4MB. That should be enough RAM for high-color display at 1280x1024.
Reply 11 of 11, by vico
I think that in PCEM you can do it.
I tried changing the BPP to 16 but Windows 3.11 stops booting.
Mode_1280x1024x8_2av = 80.0, 75.0, 1280, 1024, 16, 2048, 1280, 57864, QV08_1280x1024_2, QV_Setup_2048_2M
I have also tried with the value 32 but the image is so big that it exceeds the screen.
Mode_1280x1024x8_2av = 80.0, 75.0, 1280, 1024, 32, 2048, 1280, 57864, QV08_1280x1024_2, QV_Setup_2048_2M
Maybe I'm not doing it right.
