DOSBox performance on Mac OS X
First post, by tut21
I have a general question about DOSBox.
I'm a new Mac owner after ten years on the Windows side. When I run an ancient MS-DOS version of the text-only game Empire with DOSBox on a WinXP desktop the process barely registers in the Windows Task Manager. When I run the same game with DOSBox on my new 13" MacBook Pro it consistently uses about 30% of the processor and makes the laptop run noticably warm.
Is the Mac OS X version of DOSBox a CPU hog or is this normal for laptops? I'm also wondering if I'm comparing apples and oranges with a Dell desktop vs. the MacBook Pro.
I've tried reducing the CPU cycles DOSBox uses but that hasn't had much effect.
Reply 1 of 51, by Qbix
Rank DOSBox Author
DOSBox Author
taskmanagers can't be really trusted.
Water flows down the stream
Reply 2 of 51, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Frameskip?
1+1=10
Reply 3 of 51, by robertmo
His laptop is getting warm so I guess it can be trusted.
Reply 4 of 51, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Ubuntus task manager takes 30% for itself xD
1+1=10
Reply 5 of 51, by Qbix
Rank DOSBox Author
DOSBox Author
i mean with comparing it with his desktop taskmanager.
Reply 6 of 51, by robertmo
You mean his desktop also uses quite a lot of cpu power? I thought a text adventure can hardly be noticable by a CPU.
Reply 7 of 51, by wd
Rank DOSBox Author
DOSBox Author
You mean with a cycle count of x2=6000 he could not play the game because
the laptop would get so incredibly hot that he can't touch the keys?
Reply 8 of 51, by robertmo
I mean it should stay cool with cycles=3000 (i guess he is using 3000 not some huge amount that would explain warming)
as for 2x cycles he will have to check it -
simply thought 6000 cycles could use 60% and 10000 100%
or
still use 30% cause it was caused not by amount of cycles but by something else.
If before starting dosbox cpu usage is 0% and after you start it with a simple text game you have 30% (and the fact that your computer gets warm confirms high cpu usage) means something is wrong in my opinion. Unless of course mac normally behaves in such a strange way.
Reply 9 of 51, by wd
Rank DOSBox Author
DOSBox Author
I don't know what he's using.
Surely not. It just means that in a timeslice dosbox will run twice as
many instructions.
If 30% app load causes laptop warming, something is wrong in either the
load display or in the system setup in general. Surely not related to dosbox.
Reply 10 of 51, by tut21
Yes, the default 3000 setting. All the defaults, actually, since I don't yet know much about DOSBox.
Oh well. Thanks anyway, everyone.
Reply 11 of 51, by wd
Rank DOSBox Author
DOSBox Author
Maybe somebody else with similar system specs can check if the build behaves strange in general.
Reply 12 of 51, by CommanderKeen
DOSBox heats up my PowerBook G4 1.5 GHz (running Mac OS X 10.5.7) as hell... with the standard settings. If you want I can change the .conf file to use other settings and post a report on that too here. I also think it uses lots of CPU...
Reply 13 of 51, by tut21
Thanks for looking into it.
Yeah, I should have experimented more. The CPU usage has nothing to do with the game I was playing. Immediately after launch, when it is sitting at the command prompt, DOSBox uses about 27% of the CPU. I was just wondering if that was normal and I guess it is.
Reply 15 of 51, by HunterZ
Yeah definitely try different rendering outputs, it might be kicking your video chipset into high gear or something.
Reply 16 of 51, by CommanderKeen
This heating happens on my Mac with DOSBox 0.72, 0.73 and my own build without changes of 0.72 and 0.73. I always thought it was normal to use so much CPU ? It's an emulator so why wouldn't it ?
Reply 17 of 51, by Zorbid
With default settings, at the prompt, it eats 32% of one core on a 2Ghz Core Duo MacBook Pro.
MacBooks don't go warm easily, they go freaking hot in a whim. It's the "expected behaviour". In this case, the heat comes mostly from the CPU, not the GPU (they're each at one side of the case so you can tell who's working with your palm).
I'll try with other output methods.
Edit:
Surface, OpenGL, OpenGLnb: ~34%
Overlay:~38%
The output method is unrelated to the speed issue.
Reply 18 of 51, by DosFreak
I experienced something similiar on Linux awhile back:
Topic 12117
If you can find older builds of DOSBox for OSX and try those to troubleshoot.
On Windows you can switch out sdl.dll not sure if that applies to OSX? (Obviously not the .dll but OSX equivalent)
Make your games work offline
Reply 19 of 51, by Zorbid
Nope, it's one big unix binary. 14.3 MB...
0.72 is as gluttonous as 0.73.
Edit: same thing with 0.70.
I only tried all output options with 0.73.
