comanche 3 problem
First post, by taler
i'm trying to install comanche 3 using DOSBox. I mount everything and try to run install.exe. And it says:
insufficient extended memory to run program
Could not continue: file not found: setup.exe
i hope someone can help me.
thanks
Reply 1 of 20, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
_________________
Reply 2 of 20, by taler
ok thanks i think it works now, i just have to configure it
thank you!
Reply 3 of 20, by taler
ok now the game works, but it's very slow... anyone know what's wrong?
Reply 4 of 20, by wd
Rank DOSBox Author
DOSBox Author
dosbox version?
Reply 5 of 20, by taler
yes
Reply 6 of 20, by wd
Rank DOSBox Author
DOSBox Author
WHICH dosbox version, more precisely?
And what OS, other system specs.....
Reply 7 of 20, by taler
oh i misunderstood you...dosbox 0.72
windows xp
733 mhz p3
but i totally forgot about the ram...where do i see how much it has??
Reply 8 of 20, by Kippesoep
A 733MHz P3 is waaay too slow to run Comanche 3 at a reasonable speed in DOSBox (it can hardly keep up with the game outside of DOSBox).
My site: Ramblings on mostly tech stuff.
Reply 9 of 20, by MiniMax
Rank Moderator
Moderator
Before starting the game, try the following commands from the DOSBox prompt:
C:\> cycles max
C:\> core dynamic
_________________
Reply 10 of 20, by taler
well i did what you said and it works a little better but still not good...+ all the white lines and numbers(altitude, weapons,...) disappeared.. anyone? or is my pc really to slow for it..and what do you suggest in that case-i really wanna play a comanche game...
Reply 11 of 20, by wd
Rank DOSBox Author
DOSBox Author
At least if you want to use a full-pc emulator as dosbox.
Try vmware/virtualbox/vpc or whatever, good luck.
Reply 12 of 20, by taler
hey what about comanche gold? does it work without an emulator? i heard it's basically a re release of the comanche 3...
Reply 13 of 20, by MiniMax
Rank Moderator
Moderator
Try using just one of the commands then and see if the lines and numbers come back.
_________________
Reply 14 of 20, by taler
no they don't...
Reply 15 of 20, by MiniMax
Rank Moderator
Moderator
And if you don't type any of them?
_________________
Reply 16 of 20, by taler
no they're not there...
Reply 17 of 20, by MiniMax
Rank Moderator
Moderator
WHAT is not there?
_________________
Reply 18 of 20, by wd
Rank DOSBox Author
DOSBox Author
white lines and numbers i guess
Reply 19 of 20, by Neville
"Comanche Gold" works under XP, I played it a few months back. It even has more missions than "Comanche 3", so it's a good deal if you can find it.
