Sort of a bug?
First post, by EdusP
Using DosBox without Hard Drive image is Ok , it emulates ems and xms and almost the complete environment. Now , when i boot DosBox with a 500 Mb Virtual Hard disk i created with MsDos 6.20 , himem.sys and emm386.exe cannot see upper memory acccess. Is that sort of a bug ?
Thank for reading. EdusP.
Reply 2 of 8, by EdusP
Should i disable in dosbox.conf or when z: appears?
Because i tried editing dosbox.conf and set both ems and xma to false and didnt work.
Thanks.
Reply 3 of 8, by wd
Rank DOSBox Author
DOSBox Author
Disable them in dosbox.conf, though it shouldn't matter.
How do you determine that upper memory is not present?
What does mem.exe (from dos) tell?
As parameters for emm386 try "RAM FRAME=E000",
if it (what?) still doesn't work please post the exact error
message and the relevant parts of config.sys
Reply 4 of 8, by EdusP
With both ems and xms = true at dosbox.conf , when i boot , himem.sys tells me there is no extend memory found.
When i disable the xms and ems at dosbox.conf , himem.sys load fine , but emm386 tells Unable to set frame base address- ems unavaliable.
I think it is a sort of conflict between xms and ems emulaion (the internal DOS of DosBox) and what a real msdos try to find on the system , i dont know.
If you want my HDD image to try to find to what is happening ... i give you my email address. i have one 10 Mega Hdd image with msdos 6.20 with Norton utilities , Pctools Deluxe , Turbo pascal , turbo basic installed.
Thanks!
Reply 5 of 8, by EdusP
Thanks!
Reply 6 of 8, by Guest
My config.sys is set to :
device=c:\dos\himem.sys
dos=high,umb
device=c:\dos\emm386.exe 4096 ram
and emm386 tells thereare 0 KB upper memory.
in dosbox.conf i set 'memsize=16'
Thanks.
Reply 7 of 8, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
You must set FRAME as WD said. It will complain, but it will work.
Mirek
Reply 8 of 8, by EdusP
Ok , it did work fine. i set frame=E000. Now it is running almost like my old 386 machine with 120 mega of Hard Disk.
Thanks!
