First post, by flux1270
Hello everyone,
I've been a longtime lurker here but decided to finally make an account.
I am wanting to build a Pentium II Xeon workstation sometime this year - for no reason other than it being cool - and I need some advice or suggestions on how to get there. Most of my vintage computing experiences thus far have been with laptops, but I've had a couple older P3/P4 desktops and early Macs over the years as well.
I am primarily interested in using this build as a challenge to myself and as a way to experience early Photoshop and other pro level applications like that on real hardware.
I already have a Pentium II Xeon 450MhZ (512KB cache, 100MhZ FSB) that I scavenged from a server many years ago. It was working when pulled.
My first glance at eBay for Slot 2 motherboards wasn't promising, especially dual-slot units. Any suggestions on that front? I don't have any issue replacing thru-hole capacitors but I haven't braved the SMD world quite yet.
And lastly, in no particular order:
  • How much RAM would be appropriate? 512MB? 1GB?
  • What would be a good video card choice? I have a Radeon 8600 or something of that era, I believe it's a PCI card but not 100% sure.
Any advice/suggestions are greatly appreciated. Thanks!
Reply 1 of 29, by myne
https://www.ebay.com.au/itm/405009170749
I built:
Reply 2 of 29, by dionb
The motherboard you choose/find will determine the answer to a lot of questions.
Depending on board you might need 32b PCI VGA, 64b PCI VGA, AGP VGA or AGP Pro VGA. Similarly memory will probably be registered ECC, but EDO vs SDRAM depends on chipset/board, as does how many is feasible and if so exactly what you will be looking for.
Similarly, I/O could get interesting - nice SCSI RAID array would probably be a good match, but you may already have controller hardware on your motherboard.
Reply 3 of 29, by chinny22
My first thought when I saw the title was Motherboard.
As you have already discovered CPU's while not common are at least available, but motherboards are almost non existent.
If you're really serious maybe open up your search to OEM workstations like Dell, Compaq, etc. still not common but doubles your chances.
Even at the time Slot 2 wasn't very common. Not much benefited from multiple processors and if something did people when the cheaper multiple Slot 1 option.
I've a number of dual slot computers starting with the PPro and up, and like you have a Slot 2 Xeon I saved from a Compaq workstation I stupidly fried 20 years ago when it was just thought of as junk.
but I've pretty much given up on Slot 2 due to prices and availability.
Reply 4 of 29, by flux1270
Thanks for the replies and suggestions.
I've put eBay saved searches out for every 440GX motherboard I could find a model number for. There's a NIB C440GX+ on eBay right now but the seller wants $300 for it 😬
I'm having more trouble finding individual computers that would've had a Slot 2 motherboard. I wish I had taken that whole server back in the day but alas.
If I'm not able to get a Slot 2 motherboard at all, I guess I can always concede defeat and build a dual Slot 1 PII 450 rig - it's close enough anyway.
Reply 5 of 29, by myne
I haven't looked, but I'm moderately sure the only real difference in slot 2 is support for 4 or more processors. I'm sure there are other differences like ecc on the bus but again, haven't looked.
And I'm pretty sure the gx was the base model (dual only) chipset of the era. All serious servers used ServerWorks chipsets.
I built:
Reply 6 of 29, by flux1270
I decided to pick up a Dell Dimension XPS T500. It's coming with a P3 500 but I'm planning on swapping in a dual Slot 1 motherboard and going with either dual P2 450s or P3 500s depending on what board I get. Obviously I will keep the SE440BX-3 as a backup.
I'll pick up a more modern PSU for it. I'm thinking maybe a Radeon 9800 or a GeForce 3/4, just depends what I can find. I have an Audigy 2ZS that should be right at home in this rig.
I will probably go with 2GB of RAM. Not sure what route I'll go on storage - I've always used CompactFlash cards with my vintage laptops but I use CF heavily for my older DSLRs these days. 120GB SCSI/IDE drives can't be that hard to find, right?
The attachment s-l1600.jpg is no longer available
Oh, and I'm going to paint the case in dark pearl Krylon Fusion - if I'm building a badass workstation it's not gonna be beige.
I'll be sure to post an update when things start to come together. Thanks for your help everybody!
Reply 7 of 29, by luckybob
flux1270 wrote on 2025-01-30, 16:51:
Hello everyone, […]
Hello everyone,
Welcome! The P2/3 Xeons are pretty damn cool. I have 'enough' of them to satisfy my urges, at least for the time being. I have a lot of positive things to say about the ecosystem, and a lot of negatives. So buckle up buck-a-roo!
Slot 2 motherboards were the server/workstation systems to the pedestrian slot 1. The CPU CORE is 99.999% the same as the pleb version, however the L2 cache was bumped up to 2MB and to 100% core speed. At the time, this meant 90% of the $10000 price tag (of the 2MB chips) was the L2 cache. Which had to be painstakingly hand created by nude, grey-beard virgins at the top of mountain peaks, during a full moon, and whenever Mercury was in Gatorade. Naturally you are going to want to get some of these mythical 2MB chips and I'm just going to have you pump the breaks and tell you right now; you have a better chance of finding a virgin in a whore house. The cherry on top? 2MB isnt remotely useful for the vast majority of programs. That kind of cache was only viable if you were doing top-tier, workloads. Think nuclear explosion simulation.
To that end. the vast majority of Slot 2 systems were only sold by OEMs. Dell, HP, Compaq, etc. Supermicro is the only motherboard manufacturer of note to produce "normal" ATX slot-2 boards. Asus made exactly one board, and there are a few others, but these boards are super-ultra-mega-rare. I can count on one hand how many times my ebay saved search as pinged me for the Asus XG-DLS. In fact its TWO, in the last DECADE. The Intel reference board was used in several OEM systems, and is the easiest to come across.
Also, there were several versions of the CPU and subsequent boards. you mentioned only the Pentium 2, so you should stick to boards with the 440GX chipset. The P2 chips *should* all be safe, but make 100% sure your motherboard will support the VOLTAGE listed on the top of the CPU. 2.8V and 5v/12v are the 2 most common. You cannot use a 5v/12v cpu in the XH-DLS for example. There were some boards that did have compatibility, but don't assume here. If you try to use an OEM board, its going to require the whole system. Also, be prepared to use ECC/registered ram. Luckily this stuff is completely passed over by the retro community and you can cheaply and easily (relatively) max out a system with ram.
Once you get the cpu/mobo in your hands, THEN you can start to even think about the other stuff. If you are dead set on Slot 2, this is going to take a massive amount of patience.
Now to address the elephant in the room. Price. Unless you get lucky, I mean 1 in a million lucky, you are going to pay through the nose for a non OEM motherboard if you even find one at all. If your only concern is to fart around with old photoshop, the experience is going to be 99.9% the same on a dual slot 1. You can get dual slot 1 boards all day off ebay if you can stomach the stupid price. It's not nearly as bad as Slot 2, mind you.
so ultimately, my advise is to leave the xeon you have on the shelf, and keep watching for a deal on a motherboard. In the meantime, get used to the nuance of dual cpu machines with a slot 1 setup. If that scratches the itch for watching Photoshop crash, then you saved a large amount of cash, time, and effort. If you want to go deeper down the rabbit hole... it will be there for you, but it is dark, and full of terrors.
Reply 8 of 29, by luckybob
flux1270 wrote on 2025-01-31, 02:44:
Thanks for the replies and suggestions. I've put eBay saved searches out for every 440GX motherboard I could find a model number […]
yea, thats pretty NORMAL for dual slot 2. If I didnt already have that one...
Reply 9 of 29, by flux1270
Little update:
I purchased an Intel L440GX+ motherboard on eBay for what I felt was a decent price. No AGP which kinda sucks but I'll live. I'm going with dual Pentium 3 500s (Katmai) and 2GB of RAM.
The capacitors look good from what I could see. Everything I've found says a standard ATX motherboard will fit in the XPS T500 case and that the 440GX takes a normal ATX power supply so here's hoping.
I also picked up a 10BASE-1000/gigabit PCI NIC for it and dug my Audigy 2ZS out of the closet. Once the PC and motherboard arrive, that just leaves sourcing another P3 500, RAM, a GPU, and figuring out what I want to do for storage. Wish I still had a CRT monitor hanging around but the 27" WEGA Trinitron for my console setup is large enough on it's own.
I think I'm going to call it the Dell XPS T500^2 (squared).
Reply 10 of 29, by luckybob
"figuring out what I want to do for storage."
here is the easy peasy, lemon squeezie. solution i use for everything pentium 2 and newer.
https://www.ebay.com/itm/395420885668
they are fast, cheap, and bootable to windows 2000 and XP with no fuss. (you jsut need the normal driver floppy disk) it lets you use cheap sata SSD's and cd drives.
Just remember to disable the onboard IDE to free up IRQ 14 and 15.
Reply 11 of 29, by chinny22
While I like the Dell case (I also own a T500 and a Dimension 4100) it's going to need some work to accept a generic motherboard.
Most obvious is the Dell PSU isn't ATX, but generic PSU will fit.
Rear I/O panel will need to be physically cut away to accept the new motherboard.
The cases front panel connector will need modification, pinout can be found here.
https://www.roberthancock.com/dell/fpconn.htm
Personally, I'd keep the Dell as is and use a more modern ATX case with better airflow, pair of 2 CPU's don't mind heating up a case.
Reply 12 of 29, by eisapc
You might look for a Compaq Professional Workstation SP700 or SP750?
Got a motherboard of the first, but never got it running due to lack of a matching PS.
There is a dual Slot 2 HP Kayak XW, someone described them in a different vogons thread.
HP Kayak XU
For my ML530G1 I accidently fried the mainboard, so it does not complete POST anymore.
Lukily I did not spend any mony for the second CPU yet.
Meanwhile my need for multi CPU Xeon Systems is satisfied otherwise.
Quad, six and octo slot 2 servers are nice toys too.
Reply 13 of 29, by flux1270
Got the T500 and the L440GX+ motherboard this weekend.
The T500 needs cleaned up pretty bad but is working otherwise. Someone physically ripped the HDD cage out of the machine so that's lovely.
I've decided to get a larger ATX case for the motherboard, there's just not enough clearance in the T500 case. I'm still going to repaint the Dell and I might resell it as a Windows 98 rig.
The L440GX+ came with 512MB of RAM installed which was a nice surprise. The caps are in fantastic condition, no bulging or leaking to be seen.
The only issue I've run into so far was getting my P3 500 installed into the motherboard - the heatsink has "wings" on the edges that prevent it from slotting in. Any suggestions there, or do I need to find a CPU with a different cooler?
I need to order the 2nd CPU anyway.
Reply 14 of 29, by chinny22
I'm guessing it's the plastic clips that are supposed to hold the CPU in that are the issue and not the metal heatsink itself?
You may be able to remove the clips and just have the socket keep the CPU in, that's all I'm doing and has been ok for almost 10 years.
Pic of the CPU will tell us for sure.
Reply 15 of 29, by myne
Btw I stumbled on these
https://www.memory4less.com/hp-800mhz-pentium … ssor-166054-b21
https://www.memory4less.com/compaq-500mhz-pen … ssor-117650-b21
They're not cheap, but, hey, if someone wants them..
I built:
Reply 16 of 29, by luckybob
https://www.ebay.com/itm/176834116841
pair of processors in this one.
its about 2x what I would even consider paying, but... ¯\_(ツ)_/¯
Reply 17 of 29, by Jasin Natael
I've had a matched set of PIII/Xeon 700mhz CPUs stashed for years. Thinking I would do something with them, but boards are a bit scarce so I never have.
Reply 18 of 29, by luckybob
The attachment Untitled.png is no longer available
i-dont-need-it-v0-xwr0xv15ymid1.jpg?width=640&crop=smart&auto=webp&s=3ab625b58e2c97bc29ced4e3ce48e16d80ac9d68
Reply 19 of 29, by myne
luckybob wrote on 2025-02-10, 18:12:
There's a bunch of good ones in there
I built:
