First post, by BitWrangler
- l33t++
Hi Folks,
If you are expecting a meticulously planned, carefully researched, statistically balanced, multiply repeated, clean room, lab grade benchmark compilation and review to engrave in stone as a monument for the ages, this ain't it. What this is, is some testing I did for my own purposes, single pass, most convenient tests that were already on a disk nearby, on the motherboard I was currently working with. So on my own time, I did it how I liked, if you don't like, use your own time to do it how you like.
Approximate Test Setup...
Not the exact test setup? Read first line again. Motherboard: Asus ISA486GXi https://theretroweb.com/motherboards/s/acer-i … gxi-model-i433a RAM 4x256, 4x1MB 30 Pin SIMMs, probably 70ns. CPU Intel 486SX33, board configured to 40Mhz, ISA probably at 10Mhz. BIOS defaults timings. ISA I/O Some Prologic thing with UMC chip, HDD Seagate ST-351 A/X 40MB, ancient, I dunno about viruses, but it's probably got barnacles and toredo worms.
The cards...
Oak Technologies Inc OTI-037 based card, marked VG3000, The basest baseline, came out of a Packard Bell PB800, unknown if original to it, or a replacement. 1MB of RAM onboard.
Trident #1 Tri1 TVGA 9000A on board 4 RAM sockets, two filled for first run 256k, four filled for 2nd 512k, 70 and 80ns mixed, but slower timings probably baked into BIOS compare with #3. HNG2YPTVGA06X4LT2 is the FCCID onboard, Rev B near upper right. Apparent date mid 1991 from chip datecodes. Refused to POST until J1 opened.
Trident #2 Tri2 TVGA 8900D on board soldered 8xSOJ for 1MB 70ns, JA-8232E/V3 on board near backplate, apparently a Jaton card from mid/late 1994. Froze in the exact same place 3 times in a row in the Doom timedemo despite cleaning/jiggling, so I went looking for jumper settings and the only ones that seemed relevant were for the FIFO and wait state, even though they seemed to be set at most conservative, FIFO off and 1ws. Settings inferred from commonality of these settings on several boards, as there was not a direct ref I could find for this one. Anyway, with 0 WS and FIFO on, it seemed to like DOOM and went right through, repeated other tests, but gave the ones on "slow" setting also, minus the DOOM
Trident #3 Tri3 TVGA 9000C on board, probably, AAmazing sticker over the top of it. TV-9000C-G10 on silkscreen ... Rev B, appears pretty much identical to #1 apart from supposed to have the different revision TVGA 9000, board seems to date from early 1992. 256kB RAM installed 120ns parts, 2 sockets empty.
Trident #4 TVGA 8900CL on board 4 out of 8 RAM sockets filled for 512kB RAM 70ns parts.HNG890CL-24D1TiA1 FCCID Probably same manufacturer as #1? Or at least they stole the ID off the same one. Late 1992 is the apparent dating on this.
Trident #5 untested, empty RAM sockets, was gonna do it after but test system gone flaky in current config. Another "HNG" card.
Trident #6 TVGA 8900C on board, 8xRAM 80ns for 1024kb/1MB HNG FCCID on sticker, most parts on board would indicate early 1992, but one last week of 92 part suggests 1993, unless it was a repair.
Cardinal SnapPlus long board with Tseng ET4000AX VGA on, multifunction capture board, retired IT junk from engineering firm, a little worse for wear by time I got it. Fired up fine, ET4000AX might be set conservatively for power and stability reasons on this chonker. 1MB of VGA RAM I think.
ATI Graphics Ultra, Mach 8 chipset 1MB, version with the round busmouse port. Added for additional reference point. Seemed to do well.
Benchmarks..
LandMark 6.0 "LM 6.0" graphic speed test in characters per millisecond.
TopBench, The Old PC Benchmark, video mem access times, microseconds highest/worst value seen recorded, since it won't give avg. Lower is better.
Snooper by J. Vias. Graphics benchmark in characters per sec, only because I used it a lot in the 90s so my perceptions are tied to it.
3DBench 1.0 Superscape benchmark. In Frames per second.
Doom18s, doom -timedemo demo3, used in the classic manner, two levels of screen reduction from highest, HUD and frame. non-Phil.
Test Results, double lines are same card different config...
Card Chipset LandMark TopBench Snooper 3Dbench Doom18S
6.0 gmem 1.0 classic
Chr/ms microsec Chr/sec FPS gametics
Oak VG3000 OTI-037 482.36 1345 39,534 7.6 13,665
Tri1 TVGA9000A 9000A 1177.29 574 44,086 13.8 12,276
" " 512k " 1261.93 537 44,084 13.8 12,193
Tri2 ? 1024k 8900D 1374.88 480 44,098 15.1 *Froze
" 0 wait FIFO enabled 1800.44 424 44,105 17.5 7,047
Tri3 Aamazing 9000C 1175.89 574 44,086 13.8 12,274
Tri4 8900C 1371.05 515 44,109 14.9 12,194
Tri6 8900CL 1800.44 455 44,111 17.5 7,018
Card. SnapPlus ET4000AX 1444.41 499 44,098 15.6 7,989
ATI Graphica Ultra Mach8 1444.41 581 47,242 15.6 8,190
Discussion...
I am awarding joint first to Trident #2 and #6 and joint third to Cardinal and ATI, why those were close I think is because they both copied the same IBM chip. The rest lose. I wanted to have my Orchid Kelvin 64 with CL GD-5434 in there for the top end bracket of comparison, but due to glitchyness induced maybe by loose monitor connector, or other causes to be investigated, I kept crashing the test system with it. This introduced some drive corruption, may have affected the I/O card and I was barely able to get a doom result with the ATI because of it. This means that I might be unable to return to the specific combo of i/o card and HDD used here to compare any other cards that turn up, as they may have to be swapped out.
Trident-wise, the CL appears to be the equal of the D in 8900s, while nothing seems to separate the 9000A nd 9000C, the 8900C card miiiiight benefit from tuning and/or alternate BIOS, hard to tell.
The Tridents, numbered left to right from top.
Edit: off by one error Trident #3 sucked, #2 was the good one.
EditII: in case you can't tell I was racing to post this before I had to go do something else... correcting from GD-5430 to GD-5434 and removing a stray 256k from next to 1024kb card... Oh btw, according to LiqMat, who might be the world authority and grand poobah of all things SnapPlus in this age, the ET4000AX on these is in 8 bit mode.
EditIII: bench view with OTI added below...
EditIV: What an absolute doorknob, I got #4 and #6 switched according to their pic position in post. Resulting in #4 being bottom right on pic, #6 in results being the middle right.... then I went and referred to #6 by picture order in other mentions, meaning yes, that one on the picture, but #4 by result, doh.
