First post, by Anonymoose
Bought a sound card from a local store today, it’s a “Golden Sound GS-32 PCM Interface” and luckily it came sealed in its box so I had drivers and manuals. What I’m confused about is its sound compatibility?
I can’t find much about it on the internet, so I’m hoping someone here can help! It seems to only support general midi and ms-32, does that mean I have to pair it with another sound card? Can it do any sort of soundblaster emulation? I set my autoexec for a Soundblaster 16 just to check, and Doom acknowledges the general midi, but can’t playback any sounds (Epic Pinball crashes with any sound setting I choose.) Other than that issue, any sort of info about this card would help. Thanks 😀
Reply 1 of 10, by Grzyb
Anonymoose wrote on 2024-10-22, 20:55:
Yes, that card is obviously intended to be used together with an SB-compatible card.
No mention about SB compatibility on the box, and no SB-compatible chips on the card...
Zaglądali do kufrów, zaglądali do waliz, nie zajrzeli do dupy - tam miałem klimatyzm.
Reply 2 of 10, by Anonymoose
Alright, thanks! How would I go about connecting the two? Would I have to add another blaster line to the autoexec?
Reply 3 of 10, by Grzyb
Anonymoose wrote on 2024-10-22, 21:31:
GS-32 Line Out -> SB Line In
You mean you already have "SET BLASTER=..." in AUTOEXEC.BAT ?
But how?
It doesn't make sense for the GS-32 software to add that line...
Reply 4 of 10, by Babasha
Grzyb wrote on 2024-10-22, 21:37:
GS-32 Line Out -> SB Line In […]
But how?
Maybe its drivers write additional parameter /P:330 to SET BLASTER?)))
Need help? Begin with photo and model of your hardware 😉
Reply 5 of 10, by Anonymoose
But how?
I added that line manually just in case it supported a soundblaster. Doesn’t seem to do anything though.
Edit- I understand what you mean, I can just use the Blaster command for the soundblaster that does work and feed it through the Toptek card that has its own midi going on.
Reply 6 of 10, by Jo22
Hi. I would also check for resource conflicts. Gameport and MIDI port and IRQ, for example.
Currently, it seems gameport is OFF, but IRQ is 5 and MPU 401 is at 330.
That conflicts with most standard settings of a Sound Blaster compatible.
https://arvutimuuseum.ee/th99/i/S-T/50899.htm
Edit: One of the cards should be reconfigured for IRQ 7 and MPU port 300h, maybe.
Both were alternate addresses for sound cards.
IRQ 7 was the old setting for Sound Blasters, while MPU port 300h was also used for General MIDI games if port 330h was unavailable.
Early MT-32 games by contrast do often expect MPU port 330h only.
Reply 7 of 10, by Jccwu
no need to guess and try to get sounds from this card. It does not have a single FM chip for this.
Sound card's music
Reply 8 of 10, by Pickle
Did it come with a driver disk?
Maybe try getting it play midi without the sb16 in the system.
What sb16 model? Makes a difference if it’s pnp or not.
But key is like mentioned above is to make sure none of resources conflict.
Reply 9 of 10, by gerwin
This GS-32 is similar to two other cards: the Dream PW-32 Pro and the PowerWave. The Midi-music-only functionality of such cards is comparable to the Roland SCC-1, but unlike the Roland they usually need a driver to initialize.
The PW-32 Pro/PowerWave cards have the common Dream-SA SAM 9233 synthesizer chip, whilst the GS-32 has the older but similar SAM 9203 chip.
What is Dream PW-32 PRO?
SC8500 sound card - what does it do?
Reply 10 of 10, by Anonymoose
Hello! I'm back, this time with a new question. So I got the card working, it's a midi music only card, and it does General Midi and apparently some sort of GS-32. One of the included driver applications is for setting reverb and chorus (GS-EFF.EXE). However, when I try to set either of them, I don't hear a difference even when both are set to 127. I don't know much about midi so I'm sure I've overlooked something. Is it something with General Midi? My tests have been with Doom and Monkey Island. Any thoughts?
