First post, by aazard
So I was walking through the internets today and see:
So the Crysis of Windows 98SE is.... Crysis?
- Thats some "STEEP" requirements for a 98SE game, blows the hex hack to DOOM 3 out of the water
- Released on May 5th, 2009
(thats like 11yrs after the OS's release!)
- Unsure, but this may be the real "last" mass-market retail piece of software for Windows 9x
The "all-in-one" combo edition: Crysis Maximum Edition = "Crysis + Crysis Warshead+ Crysis Wars"
Look Closely: this one has 98SE/ME, not just 2000 (like some of the "Original" disc releases of "Crysis" had Windows 2000 listed)
dos-backups-v0-4imzr6bn4upd1.jpg?width=1200&format=pjpg&auto=webp&s=430156d392ec9eed414e734b2034049e200f4121
Aazard -
Mono Planar Mortal & Unascended Master
Retro Enthusiast & L3 Trouble Shooter
.... Getting old
Reply 1 of 12, by DosFreak
For 2000 you had to use a wrapper (or modify game files) and copy over some XP dlls. Nowadays (and for years now) BWC would be the way to go.
For 98SE you might be able to get away with kernelex w/updates assuming you had a supported GPU, drivers and rloew memory patch.
Make your games work offline
Reply 2 of 12, by aazard
DosFreak wrote on 2024-09-19, 21:57:
it's straight up listing 98SE/ME as "supported" on box details, am I missing info?? (I found reddit conversations of a user hoping to try to install/play it, but it is reddit so "grain of salt")
https://www.reddit.com/r/windows98/comments/x … n98se_possible/
Aazard -
.... Getting old
Reply 3 of 12, by Tiido
I have very vague memory of running the game on a P4 with X850XTPE, running 98SE + Kernelex and it started and gave you a slideshow but was nothing along the lines of playable. The game definitely won't run on vanilla 98SE and KernelEx is necessary for sure.
Reply 4 of 12, by aazard
Tiido wrote on 2024-09-19, 22:41:
I'm going to see what I can dig up from the time of release, even then, this "listing 98SE" would have raised eyebrows...someone in the past must have tried "at the time"
Edit: Also, I'm pretty sure the 1st time I played Crysis it was on a ATI 9800xt 256mb, over AGP, on a late era 478 p4 (I think it was a 3.0ghz 800mhz FSB) rig, on XP
"in era" I could never get it to run well or maxed out
Aazard -
.... Getting old
Reply 5 of 12, by leileilol
aazard wrote on 2024-09-19, 21:36:
- Released on May 5th, 2009 [/b] (thats like 11yrs after the OS's release!)
Crysis was 2007.
Crysis was heavy because a lot of inefficient memory-reading on the GPU and the overdraw strained everything (new ambient occlusion effects plus water reflections) so it got memed as the ultra computer killer.
long live PCem
Reply 6 of 12, by aazard
leileilol wrote on 2024-09-19, 23:27:
Crysis was 2007
"Maximum Edition". tri-dis release was released on May 5th, 2009 (where the spec list "98SE & ME" on box/case)
https://gamefaqs.gamespot.com/pc/956125-crysi … um-edition/data
dos-backups-v0-ssnrnk2m4upd1.jpg?width=1340&format=pjpg&auto=webp&s=0619174dc974b28a722ca7dcd66c5446724e15bb
Aazard -
.... Getting old
Reply 7 of 12, by eddman
Print error. Euro releases say Vista/XP.
Reply 8 of 12, by akimmet
I am certain what you are seeing is a print error. I remember dealing with the hacks to get Warhead running on Windows 2000.
Reply 9 of 12, by aazard
Looks like the consensus is "100%, that's a print error"... seems NOT present on all other releases of included games/add-ons as well.
Shame, that would have been a very late 9x compatible "AAAA" game release
Aazard -
.... Getting old
Reply 10 of 12, by fosterwj03
I have this version of Crysis, and it doesn't install on Windows 98SE. It gives an "Unsupported" type error. It does install on Windows 2000 with the Vanilla kernel (no mods required to run it in my experience).
Reply 11 of 12, by fosterwj03
I just realized that I never tried to install my copy of Crysis on Windows Me. It might work...
I'll have to give it a try tomorrow if I find the time.
Reply 12 of 12, by fosterwj03
Nope, it doesn't install in Windows Me either. The error message says it needs a minimum of Windows 2000 SP3.
