First post, by Tempest
- Member
I was attempting to use an 8GB CF card with my Gateway 2000 4DX2-66V but the system only seems to recognize it as 504MB or so hard drive. The BIOS is version 0.10 (Phoenix BIOS). Would updating the BIOS help overcome this limit or do I have to use something else like XTIDE BIOS?
I found one BIOS file but it's the same .10 one I have. Maybe this is the only one? https://theretroweb.com/motherboards/s/micron … 9-00189-xx#bios
Supposedly Micronics themselves had a different BIOS that might work better. Not sure where to get it though https://www.rigacci.org/docs/biblio/online/fi … are/mfibios.htm (M4HS45G 4.05.17)
The BIOS *did* allow me to manually set the hard drive size but it uses that cylinders/heads notation that I don't understand. Would this allow me to use the 8GB HD (or at least have it see it as 4GB)?
--- AtariProtos.com ---
For when excellence and burnished fineries need to gently visit the warmth of your tablery
