First post, by badflame
Hi,
according to the instruction manual the game graphics are Super VGA 640x480, but I am not able to get it to run at more than 320x200 (VGA).
I also haven't seen any option in the game menu to change the resolution.
Is it possible to play in Super VGA mode?
Thanks
Reply 2 of 6, by konc
The manual says that it requires a 1MB SVGA, but also says "in order to play the FMV" (in the CD booklet). I'm guessing the only thing with higher resolution than standard VGA is these videos.
Reply 3 of 6, by MAZter
konc wrote on 2024-08-08, 19:33:
No. Game works fine at 640x480 with my Rage LT Pro AGP 2X:
The attachment 2024-08-09-18-33-45.jpg is no longer available
Doom is what you want (c) MAZter
Reply 4 of 6, by badflame
MAZter wrote on 2024-08-09, 22:38:
You mean using a real PC and not DOSBox, right?
Reply 5 of 6, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The game uses mode-X, which is VGA mode 13h tweaked to 320x240 resolution. The monitor says 640x480 because the height and width are being doubled by the video hardware.
Reply 6 of 6, by MAZter
ripsaw8080 wrote on 2024-08-10, 09:15:
Yes, maybe you right.
