First post, by Guardian_Misterioso
I am having problems with the "Olympic Games Atlanta 96", since when I am about to play the swimming event after having completed 9 of them, the game crashes and exits to the promtp with the following error message in the secondary window:
ret from illegal descriptor
Additionally, it should be noted that every time I try to access a new event, the following message appears in the secondary window:
redirect output to null
I have tried changing cycles, making different memory selections and also changing the cpu type, without success in any of the cases. Additionally, I have tested both the official version of DOSBox and DOSBox SVN Daum and DOSBox-X. Could anyone tell me what I should do so that the game doesn't crash when it is time to play that especific discipline?
Thanks in advance.
Reply 1 of 3, by TheWiredIsUponUs
How are you running the game? Game ripped to the hard disk, or from the ISO image?
Reply 2 of 3, by Guardian_Misterioso
Since I no longer have a PC with a physical CD drive, years ago I made CD images of my entire collection, including this game. So this is an ISO (BIN/CUE) that I mount with the imgmount command or I mount the Daemon Tools virtual drive where I run it.
Reply 3 of 3, by TheWiredIsUponUs
The game requires the CD to be mounted in order to play the game. You could find a crack of it somewhere, I guess, which might fix the issues that you was having earlier; otherwise, try a different DOS emulator.
In my opinion, the best DOS emulator would have to be DOSBox-X.
