DTK PAM-0056I E0
First post, by Freemaxx
Hello, I am in the process of upgrading a DTK motherboard PAM-0056I E0.
I replaced the keyboard connector with two ps/2 (keyboard/mouse). I added a coast of 256ko. I modded the Dallas chips and the bios. I put a connector for a CPU fan.
But my card does not support Pentium MMX and dual voltage. Some models equipped with 2 Q2 transistors do this. Does anyone have this model and tell me which ones they are? What else would be missing?
My Q2 is a D1062. I added jumpers in place of the S1 S2 S3 bridges and shifted the Q2.
Sincerely.
https://theretroweb.com/motherboards/s/dtk-pam-0056i-e0
Reply 1 of 5, by P0113N
Hello
I also have one of these motherboards, which was also a single transistor model, but I successfully modified it to a dual transistor one so that the motherboard supports dual voltage processors.
The parts I used for the modification are:
- some pins for the jumpers
- 1 pc. TL431CZ voltage reference ic
- 2 pcs. MJE13009 power transistor
First you need to remove the jumper wires from the S4 S5 S6 locations and solder pins instead.
You need to remove the D1062 power transistor from the middle. Then you need to solder the MJE13009 power transistor to the two outer locations Q1 and Q2.
After that you need to solder a TL431CZ voltage reference chip to the Q3 location.
That's it, if everything went well it should work.
Reply 2 of 5, by Freemaxx
Hello,
Thanks you for your answer .
A person who was selling a dual transistor card on a peer-to-peer sales site sent me some photos. I put 2 sd1062 and it works. See you soon
Reply 3 of 5, by Freemaxx
This pics...
Reply 4 of 5, by Freemaxx
I just noticed that there would also be a 220 ohm R189 resistor to add.
Reply 5 of 5, by timmcross
So glad I found this thread! I am trying to do the same mod. I added 2 d1062 transistors with a tl431 transistor. When configured for split voltage, I get 2.9 v and 4.2v. Plus the added tl431 gets really hot during operation. Anyone else see this? I believe the 4.2v should be closer to 3.4v
