Reply 34980 of 56004, by Horun
- l33t++
Bought a Harris CS82C286-20 to replace a very hot running AMD R80286-16, for those that do not know: Harris and Seimens 286 typical 1 to 1.5W where most AMD and Intel are about 3W or more heat dissipation. Should run cooler in my small form desktop case with bad airflow, just because I want it that way :p. Also bought local a HP 8230e (date 2000) and a BSR 6800MX (date 1992) external cdroms. The HP came in original box and drive still wrapped in the pink plastic sleeve, appears never used. Both power up OK and their doors open (tested that far before buying). Will have to play around with it all this weekend... I spent a total $13 on the drives and another $10 on the cpu. Not bad for stumbling on to some old stuff locally..... bet it does not again for a while.....
