Reply 34980 of 59372, by seleryba
seleryba wrote on 2020-06-29, 22:24:
https://www.vogons.org/thumbs/42095_62a9a1ac616a25975c299bacdb507f17/vog4.jpeg Inspired by LGR, I've bought full-metal aluminium […]
Inspired by LGR, I've bought full-metal aluminium case. I'll build a Tualatin PC on it. Can't wait for the package!
Ah shit. The package arrived and it comes out that front panel is made of plastic. Seller said in the description that this case is made of aluminium. Indeed, but like almost every other case...
I will still use it for some build anyway.
Fortunately, inside the case I have found this beauty:
The attachment IMG_4260.jpg is no longer available
I love Yamaha drives and it will fit for some Pentium/K6 build like a charm. A blessing in disguise!
Reply 34981 of 59372, by Horun
Bought a Harris CS82C286-20 to replace a very hot running AMD R80286-16, for those that do not know: Harris and Seimens 286 typical 1 to 1.5W where most AMD and Intel are about 3W or more heat dissipation. Should run cooler in my small form desktop case with bad airflow, just because I want it that way :p. Also bought local a HP 8230e (date 2000) and a BSR 6800MX (date 1992) external cdroms. The HP came in original box and drive still wrapped in the pink plastic sleeve, appears never used. Both power up OK and their doors open (tested that far before buying). Will have to play around with it all this weekend... I spent a total $13 on the drives and another $10 on the cpu. Not bad for stumbling on to some old stuff locally..... bet it does not again for a while.....
Reply 34982 of 59372, by Caluser2000
Bought this https://www.trademe.co.nz/Browse/Listing.aspx?id=2684174937
Reply 34983 of 59372, by Horun
Caluser2000 wrote on 2020-07-04, 03:01:
Nice and super clean ! Is that one with those hybrid plastic+metal liner case tops ? Have seen those before on Unisys and some other older good OEM computers. Internally very good, only quirk is some occasional patina (yellowing) on the lid that does not match the front, but yours looks great.
Reply 34984 of 59372, by computerguy08
Managed to get these things today:
The attachment 20200704_102240.jpg is no longer available
2 x Celeron Tualatins @1.2GHz
512MB SO-DIMM SDRAM
2 x 256MB PC800 RIMMs
5.25" floppy disk box
All of them for just 8€.
Reply 34985 of 59372, by Turbo ->
Bought a Schneider CPC 6128 computer with green monitor GT 65 yesterday. Other components came as a gift. I don't know much about these Schneider computers, so I will have to google and youtube it in future weeks.
Reply 34986 of 59372, by PTherapist
Turbo -> wrote on 2020-07-04, 09:08:
The Schneider/Amstrad CPC is a pretty decent computer. You can buy or build an RGB Scart cable and connect it up to a TV instead, if you want colour.
As you have the 6128 which comes with a 3" floppy drive, it should be relatively easy to add a Gotek in it's place to load disk images, rather than having to deal with the more obscure 3" disk format. You also have a DIN connector for connecting up a cassette player, so you could use that to load .cdt or .wav files from your PC or phone, or use something like a TZXDuino device. But personally I'd just go with the Gotek (with FlashFloppy or HXC firmware) for faster loading.
With regards to the games - a lot of games released for the system never fully took advantage of it's capabilities, instead often being straight lazy ports from the ZX Spectrum and thus looking and performing terribly with low frame rates. In comparison to other 8-bit systems of the era, the CPC is certainly one of the more capable ones and there are some games where the CPC excels over the C64 for example - though not very often.
Reply 34987 of 59372, by liqmat
I remember when I thought 128K was a lot of memory. Ahhhh... the 1980s. They were exciting times for us computer nerds.
Reply 34988 of 59372, by Master_Shifu
Had a very lucky find today... Bought a Roland SCC-1 for under 30 euro's. Was listed as a Roland ISA Expansion card, no model number mentioned in the ad title or description. Only the silkscreen print on the picture gave away the rare find. And I snapped it up right there and then 😁 😁
Reply 34989 of 59372, by Caluser2000
Horun wrote on 2020-07-04, 03:16:
Thanks. Yes very similar in design to my AcerAcross system but full AT. The yellowing will be easy enough to remove.
Reply 34990 of 59372, by gex85
So I finally received this beauty today:
The attachment Pro266TD Master-LR.jpg is no longer available
MSI MS-9105, aka the Pro266TD Master-LR. Dual Tualatins + AGP + LAN + RAID + DDR RAM (I know...).
It came with two 1133 MHz P3-S Tualatins that were immediately replaced with a pair of SL5XLs (P3-S 1400 MHz, aka "The King").
Now I need a worthy case (preferably Lian Li full aluminium) to accomodate it, and I still have to decide on the other parts for the build. Probably a GF4 Ti4200 that I already have, and a Terratec DMX 6fire 24/96 sound card (or some Audigy model). It's tempting to throw in the Voodoo 5 5500, but that would work best with Win98, which cant't make use of the dual CPUs. A period correct choice would be a GeForce 3, but I don't own one and while the Ti 200 can be had rather cheap, the Ti 500s are pretty expensive.
(Edit: By the way, the only thing that is downright awful about this board is the placement of the capacitors next to the CPU sockets. It significantly narrows down the choice of CPU coolers and makes their installation "adventuresome", to say the least.)
A nice find that I expect to arrive within the next few days was this EpoX EP-7KXA, paired with a 550 MHz Athlon:
The attachment EP-7KXA.jpg is no longer available
I spotted it as part of these "hey I have this box full of old computer parts, come and pick'em up for free before I take everything to the scrapper" listings on eBay classifieds.
Fortunately the guy was kind enough to send this particular board + CPU so I was able to get it for the cost of shipping, now I just hope it still works 😀
And a few days ago, I was able to find the SB Audigy2 complete with the Live Drive front panel and all cables in good condition for a decent price, which will probably make its way into my Athlon XP3200+ / Radeon 9800 Pro build:
The attachment SB Audigy2 - 1of2.png is no longer available
The attachment SB Audigy2 - 2of2.png is no longer available
My retro computers
Reply 34991 of 59372, by Almoststew1990
I bought some retro hardware for the first time in a while. A local advert for £10 and it had:
ABIT V6P with 2x 750MHz CPUs and some nice coolers
MSI 650 Ultra with a Willamette 1.6GHz CPU and 768Mb
Generic Socket A motherboard with 128Mb SDR RAM and an Athlon XP2000
Nvidia GeForce 5900XT (WinFast A350)
S3 Savage 4 Pro
A few MX440SE's and general junk!
Happy with my purchase!
Reply 34993 of 59372, by chrismeyer6
gex85 wrote on 2020-07-04, 20:50:
So I finally received this beauty today: Pro266TD Master-LR.jpg MSI MS-9105, aka the Pro266TD Master-LR. Dual Tualatins + AGP + […]
That dual board is a great buy and will make for a really fun system to play with.
Reply 34994 of 59372, by Horun
computerguy08 wrote on 2020-07-04, 08:02:
Managed to get these things today: 2 x Celeron Tualatins @1.2GHz 512MB SO-DIMM SDRAM 2 x 256MB PC800 RIMMs 5.25" floppy disk box […]
512MB SO-DIMM SDRAM
Almoststew1990 wrote on 2020-07-04, 20:51:
I bought some retro hardware for the first time in a while. A local advert for £10 and it had: ABIT V6P with 2x 750MHz CPUs and […]
S3 Savage 4 Pro
That is great ! Glad some are able to still get some good stuff for a decent price !
Reply 34995 of 59372, by Horun
Sucks living on west coast of US, there is never anything good like what you all found ! Too many scalpers that grab and then sell each separate for very high prices.
Reply 34996 of 59372, by feipoa
This is my overall favourite dual native Tualatin board. I think I paired mine with GF4 Ti4400. Do you plan on overclocking it? It doesn't appear to have BIOS adjustments for CPU voltage, so the fastest I could get stable performance is about 1.5 GHz. I think it could do 1.54 GHz stable, but I wanted to take it down a notch.
Reply 34997 of 59372, by gex85
feipoa wrote on 2020-07-05, 01:42:
I haven't decided whether to try overclocking it or not... Over the years I have accumulated a collection of ~15 P3-S CPUs (1.13GHz, 1.26GHz and 1.4GHz models) so chances are pretty good that I have a pair that overlocks well enough, but finding it might be a time-consuming task 😉
My retro computers
Reply 34998 of 59372, by CMB75
gex85 wrote on 2020-07-05, 08:06:
My favorite is the Gigabyte GA-6VTXD because it’s easygoing for overclocking, features an AGP port and is ISA port capable. That’s why it’s my go to machine for “performance” gaming spanning from MS DOS 6.22 up to Windows XP early 2000 games. 😀
Reply 34999 of 59372, by gex85
CMB75 wrote on 2020-07-05, 09:35:
I have been looking for a GA-6VTXD, too. So far without success.
I do have a GA-6VTXDR-C however, which features the same chipset (Via Apollo Pro) and even comes with onboard LAN and RAID, but unfortunately instead of the AGP slot it has onboard Video, which is really lame. I haven't investigated the BIOS settings so I don't know whether or not it has the same overclocking capabilities as the GA-6VTXD. To make it usable for retro gaming I would have to find a decent PCI video card, probably something like a GF4 MX or an FX5200...
My retro computers
