llm wrote on 2022-05-04, 05:16:
its version 1.34 - the french version
Was talking about the one was incorrectly dated December 8 of 2020 and has the empty folder UNKNOWN_TIMESTAMP along with it.
found it, there are also some SBTALKER.EXEs in the archives - sadly my 7zip can show me the content of the LZHs but not uncompress, but maybe Akuma got the right tools
Yep, it cannot be extracted with 7-zip. It would require using the DOS LHA extractor or a different software capable of doing this.
If using the DOS application, don't use vanilla DOSBox as it will set the incorrect timestamp. Use DOSBox-X or a real machine for this.
VIA C3 Nehemiah 1.2A @ 1.46 GHz | ASUS P2-99 | 256 MB PC133 SDRAM | GeForce2 GTS 32 MB | Voodoo2 12 MB | SBLive! | AWE64 | SBPro2 | GUS
