Reply 60 of 268, by yyzkevin
Bondi wrote on 2021-03-15, 09:22:I don't mind doing this, but I have no idea how. As for the drivers, here they are. I include the autoexec.bat, the two files t […]
yyzkevin wrote on 2021-03-15, 08:32:What would be quite helpful would be if somebody could dump the CIS off the ibm card, with that along with the drivers I could work backwards to make something compatible with the existing software.
I include the autoexec.bat, the two files that are loaded and the archived whole drivers folder. There is nothing in config.sys apart form standard IBM CS and SS drivers.PATH C:\WINDOWS;C:\WINDOWS\COMMAND;C:\DOS;C:\VC;C:\VR;C:\MWD\MANAGER;C:\ALTEC
SET TEMP=C:\DOS
REM IBM 3D Card requires CS and SS
SET MWROOT=C:\MWD
SET MWPATH=C:\MWD\MANAGER;C:\MWD\MWGAMES
LOADHIGH C:\MWD\MANAGER\MWPCMS.EXE
LOADHIGH C:\MWD\MANAGER\MWDGAME.EXE
SET BLASTER=A220 I5 D1 P330MWPCMS.EXEMWDGAME.EXEMWD.RAR
Funny enough that is where I live and grew up, Scarborough and Pickering are beside eachother.
There must be favorable atmosphere for PCMCIA sound cards developers in that area 😁
thanks! in terms of the card information structure, if you could run the following command, the 1 is socket number so maybe you would need a 0 depending which slot you put it in. dtpl.exe you should be able to find online, if not I could attach it.
dtpl.exe -r 1 > dump.cis
