Reply 16760 of 29178, by Doornkaat
BetaC wrote on 2020-09-20, 07:13:I managed most of the cabling within my general purpose 98SE/Late-DOS/W2k system, freeing up some extra resources that can eventually find their way in to a Pentium/S7 build I want to eventually do. I can still work a little more to make it completely clean, but I'm good for now.
Hi! Browsing the thread I noticed you haven't (yet) got the J12 and J13 jumpers shorted on your GA-6BXC despite using a Voodoo3 3000 AGP.
Just in case you didn't know: Those jumpers are intended for use with Voodoo3 cards. The original AGP VRM on many Gigabyte boards would often overheat when a Voodoo3 or Geforce card was used so they incorporated those jumpers on later revisions of affected boards to bypass the VRM and feed the slot 3.3V directly from the ATX PSU.
If you haven't done so already I recommend setting the jumpers so your board doesn't fry and potentially take the graphics card with it like it happened ever so often back in 1999.
Cheers! 😀
