Reply 440 of 930, by thierry
Looks very good , I can't wait to try it
Reply 441 of 930, by FreddyV
I did not wait to correct the .XM Loading and Tone portamento problems to release the Beta 19.
I am soo curious to know if you will like the add of some Adlib file format.
As Claimed by MobyGamers, I removed .MON support for the moment, the file size is smaller with .MON removed and .RAD, .IMF,.RAW and .DRO added 😀
27/05/2020 Beta 19
- Internal variables removal and rename.
- S3M : Corrected a problem in the Adlib instruments loader (OLD S3M Version files)
- Adlib replay code changed to use a Timer IRQ only.
- Correct problems in Adlib volume. (S3M / SAT)
- Added support for the internal file format (.MMM) (No converter Yet, otherwise I will never release this version)
- Added the support for .IMF, .RAW and .DRO Version 2
- Added support for .RAD version 1, RAD Tracker code integrated for perfect support.
- Fix: ESS Audiodrive Model detection and can be used as a SB Pro.
- Started OPL LPT Support (Not active yet)
The attachment MODMXT19.zip is no longer available
Reply 442 of 930, by root42
Great update! A few bugs and feature requests:
1) in my RAD folder where RAD Tracker 1 is located, I can't see any subfolders, maybe because there are no files for the player itself? Weird...
2) When you leave modm.exe in pattern view mode and start off with an Adlib file, you get the pattern view with garbage.
3) When pausing Adlibt tracks, the notes play on. Can we turn off the volume for the channels and resume them after unpausing?
4) DOS shell doesn't work anymore. Even when loading a small file.
Video:
https://youtu.be/EVRgbB4Ey1k
YouTube and Bonus
Reply 443 of 930, by FreddyV
So fast test 😀
The pattern display problem should be there only with .RAD as I forced the display change in other formats.
I had the problem with no folder displayed, I think it is because they are too many folders.
Dos shell is ok under dosbox, not tested on real hardware since soo many time 😀
I know, pause is not perfect, this is part of what I still need to do, I wanted to release this.
Reply 444 of 930, by root42
Have a look at the video. There are not many folders... Not sure why it happens. DOS Controller handles it just fine.
YouTube and Bonus
Reply 445 of 930, by FreddyV
And if you change the folder name, no more RAD ?
Mode the sub folder somewhere else
Rename other sub folder, remove some of them, to try to see when it work ?
Reply 446 of 930, by root42
Look at this:
https://youtu.be/ADXyvIfm47U
It seems it was simply the directory that it couldn't read. No idea why. Deleted, created newly, and it works. Maybe damaged file system? But why could DC read the directory??
YouTube and Bonus
Reply 447 of 930, by root42
I might have found the problem:
The attachment Bildschirmfoto 2020-05-27 um 18.57.41.png is no longer available
Anyway, the problem was gone now, after delete and re-create. I will look out for further problems.
YouTube and Bonus
Reply 448 of 930, by zyga64
Thank you FreddyV for extending Adlib support ! It would be great to see .a2m and .amd support some time...
I've also tested some other files and it seems that all RAD files are ok.
But SAT definitely sounds different than played by Surprise Adlib Tracker 2 itself.
One more thing. Pressing escape while playing attached onward_n.dro doesn't mute sound, and last played sound sounds still, even after program exit.
Moreover if this great song finishes I can hear something like mains hum. Even ALT+CTRL+DEL doesn't stop it. Only power off helps 😀
Do you think it may be related to my sound card ?
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-3+@400 /64M /Rage Pro PCI /ES1370+YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 449 of 930, by thierry
root42 wrote on 2020-05-27, 14:58:
Great update! A few bugs and feature requests: […]
Video:
Is it possible to share some modules that you use? is why I want to test on a PC XT 8088, CGA, SBPro 2.0, thanks
Reply 450 of 930, by FreddyV
zyga64 wrote on 2020-05-27, 20:15:
Thank you FreddyV for extending Adlib support ! It would be great to see .a2m and .amd support some time... I've also tested so […]
Thanks for your feedback.
The onward.DRO is a .a2m I recorded under DOSBOX.
Adlib tracker 2 is really too complexe to be added, it contains a huge number of commands, macros and so on.
That is why I had the idea to add the .RDO support to be able to play everything.
I spend 3 weeks on these adlib formats and need to do something else for the moment.
What is your sound card ?
I tested with dosbox and 5 different sound cards model and I don't have this problem.
Reply 451 of 930, by FreddyV
thierry wrote on 2020-05-28, 04:54:
If you download Reality adlib racker, there is a lot of .RAD files with it.
You can find a lot of files there as well: https://modland.ziphoid.com/
By the way I am also looking for more files, for examples, I don't know if somebody recorded games music in .DRO format.
I found lot of .RAW in another Vogon thread.
Reply 452 of 930, by FreddyV
root42 wrote on 2020-05-27, 16:59:
Cool,
You can say what is nice as well, not only problems 😀
Reply 453 of 930, by FreddyV
I had debate with some peoples in facebook group, and even in my association with Amiga Fan telling that putting an SB16 or GUS in an XT is not normal.
For me, all this is to show what an XT can do, the 286/386 were out some years after the XT came.
Then, like for the amiga 1200/Atari STE or atari Falcon, software developpers stopped to develop for them quite fast.
Also, I bought my Amstrad PC1640 in 1989, when the Sound blaster was already there…
So, what is the problem to put a Sound Blaster in an XT ?
My Main PC is an i7 form 2012, and I changed its graphic card in 2018 it makes 6 years of difference, more than putting a GUS in an XT computer from 1988.
I did put an AWE64 in the PC1640 and I recorded some module 😉 For me it is fun, for my colleagues, it is useless...
Reply 454 of 930, by root42
Amiga fans are funny. They had basically selling the same architecture over 7 years. Sure, AGA came along but those were the last few models before Commodore went bankrupt. The Amiga was great when it arrived. But it never evolved.
So why not put an awesome soundcard in an XT? 😀
YouTube and Bonus
Reply 455 of 930, by FreddyV
There is one amiga fan in my team. when I said Tandy is a legendary machine in the USA, he laughed.
Just some minutes ago….
Each time I buy an XT, he say another useless machine.
Of course Amiga is better than an XT, but they are part of the history and I like to show what they can do
Reply 456 of 930, by JazeFox
Thank you for this! I use this player regularly on my XT machines and some old Amstrad PCs (my 2086...) , and it's a must have!
Nice job!
I also use it with "modern" sound cards on XTs/ATs, and i don't see a problem with that... on the contrary... they are usually cheaper.
Reply 457 of 930, by FreddyV
I found I used an older version of the DRO player in this release that do not clear OPL3 registers at the end.
So I did this small update, correcting the RAD partition display as well.
I keep the same version as it was supposed to be this way before.
Reply 458 of 930, by root42
FreddyV wrote on 2020-05-28, 18:13:
Oh I have to remember this trick for our customer :^) Well usually we would increase the build number...
YouTube and Bonus
Reply 459 of 930, by FreddyV
I am the boss of my SW, I do what I want 😀
