First post, by vorob
Take a look: https://youtu.be/fxD89sRMA48
I'm on Compaq Evo n400c with ATI Mobility M1 which is Ati Rage Pro actually.
Tried pure dos and windows 98, no luck
Reply 1 of 10, by root42
Maybe it's simply bad VGA compatibility in the Ati. Keen uses some sophisticated EGA and VGA features.
YouTube and Bonus
Reply 2 of 10, by ynari
root42 wrote on 2020-02-27, 09:35:
Yep, see https://gona.mactar.hu/DOS_TESTS/.
Try a different card, or use DOSBox, Keen 4-6 under it is indistinguishable from real hardware.
Reply 3 of 10, by root42
ynari wrote on 2020-02-27, 09:45:
Wow. That is one extensive matrix! Nice link!
YouTube and Bonus
Reply 4 of 10, by keenmaster486
There is a patch to fix ATI compatibility problems in Keen 4, 5, 6:
Re: Keen 4-5-6 choppy scrolling on EGA card
World's foremost 486 enjoyer.
Reply 5 of 10, by K1n9_Duk3
Here's a more up-to-date version of my Keen 4-6 fixes. https://pckf.com/viewtopic.php?f=4&t=6192
I think you'll get better results with these updated patches. But the new code does introduce a slight delay after updating the screen, which may be noticeable on rather slow systems (286 and below). Just use whatever seems to work best on your system.
Reply 7 of 10, by K1n9_Duk3
If you want that border, give Omnispeak a try.
Reply 8 of 10, by ynari
leileilol wrote on 2020-02-28, 03:11:
losing that border is pretty distinguishable
Oddly, I don't remember a cyan border, so either I was being blind when doing a comparison (I did a Dosbox vs Real DOS Keen 6 A/B comparison), or it doesn't appear on my system. I'll have a look again tonight..
Reply 9 of 10, by K1n9_Duk3
That border is the "overscan" area. As far as I can tell, it's only visible on real hardware when connecting the monitor via a VGA cable, not DVI or HDMI or whatever. It's also possible that more modern CRT and/or LCD monitors adjust the position of the display so that the overscan area is not visible. But it's definitely visible on old CRTs.
Reply 10 of 10, by maxtherabbit
it's also visible through the OSSC
