First post, by KennyPowers
I have an old Acer 5200LR (looks like this) that I mostly use for DOS gaming. We had several short power outages yesterday, and now the PSU won't start when pushing the power button on the front of the case. This PSU is not a type I'm familiar with. It has the AT-style P8 and P9 connectors for the motherboard, but also has a 3-wire connector (black/white/red) to the motherboard:
https://i.imgur.com/GkKksqy.jpg
There is no power switch connected to the PSU itself like a typical AT PSU. The momentary power button on the case connects to a 2-pin header on the motherboard similar to an ATX PSU. I don't see any obviously failed components inside the PSU (leaking/burst caps, burn marks, etc):
https://i.imgur.com/KbbqIg2.jpg
The black/white/red wires from that 3-wire connector to the motherboard are labeled "GND", "ON/OFF", and "+5V" respectively on the PSU's PCB:
https://i.imgur.com/oozGt2M.jpg
The other weird thing is that I actually did eventually get the PSU to start and the machine to boot fine *twice* after messing with it for a long time. Both times it happened when plugging the power cord into the PSU (not when pushing the power button). After it happened the first time, I sat there and plugged/unplugged the PSU dozens of times before it successfully started again...seems totally random. After the machine successfully boots in this manner, if I shut it off by holding down the power button on the case, the power button will not start the PSU again...you have to go back to the plug/unplug crapshoot.
So, is this PSU shot? If so, what can I use to easily replace it? I searched for the part # and didn't find any for sale on ebay or anything. Here are some additional pictures of the PSU and its labeling:
https://i.imgur.com/3IFV2CQ.jpg
https://i.imgur.com/UsPF3dP.jpg
