Reply 28260 of 55583, by appiah4
stalk3r wrote:
bjwil1991 wrote:
The Joystick DB15 to MIDI adapters? Bought one a long time ago and it has a DB15 port that allows me to hook up my joystick to my computer whilst playing MT-32 games on my Socket 7 (this was before I bought an MPU-401 clone card) and I still have the cable for testing the sound card's GamePort for issues.
Yes, that's the one. It is sold out practically everywhere.
The pinout is really simple for that; just get a local electrician to build you one.
Reply 28261 of 55583, by cyclone3d
You could also build one yourself with a no-solder DB-15 connector from China and a couple AT Keyboard Style cables.
And then whatever cables you need for the joystick connectors.
DB-15 male connector:
https://www.ebay.com/itm/DB15-Male-2Row-15Pin … ll/302427960368
DB-15 female connector:
https://www.ebay.com/itm/DB15-D-SUB-2-Row-fem … CK/283334916626
Just add the resistors and you are good to go. If you don't want to solder anything, you can even get the no-solder lug connectors or crimp connectors.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 28262 of 55583, by stalk3r
cyclone3d wrote:
You could also build one yourself with a no-solder DB-15 connector from China and a couple AT Keyboard Style cables. […]
Wow, these solderless connectors I didn't even know existed. I have a soldering iron though so I might try to build one. Thanks for the info.
Reply 28263 of 55583, by Daniël Oosterhuis
Got this last weekend, an ASUS P4T-M Socket 423 motherboard. Came with a 1.7GHz Willamette P4 and 2x128MB of Kingston ValueRAM PC800 RDRAM, with the other two slots having CRIMMs. I paid more than I would've liked (€40), and I'd have prefered the full ATX version or even the P4T533 version with higher RDRAM speed support, but Socket 423 stuff is getting hard and expensive to find as is, so I grabbed this after a good while of contemplating it 🤣
Image removed for copyright reasons.
Reply 28264 of 55583, by SpectriaForce
NIce find. I would say that's a really good deal for a really good set. S423 boards are indeed hard to find in our country 😀 S370 and especially S462 everywhere but not S423!
Reply 28265 of 55583, by RandomStranger
I think s423 is hard to find (for a reasonable price) everywhere. It was a short lived socket. Most boards that are going around are looted from work stations. The CPUs and RDRAM are dirt cheap everywhere, but there are no boards. It really is a good catch.
Reply 28266 of 55583, by Cyrix200+
I have a Socket 423 to Socket 478 adapter somewhere.
Should have been the other way around 😉
1982 to 2001
Reply 28267 of 55583, by amadeus777999
Got this Compaq board(PL4600C presumably) and although it's far from fast, despite the beefy UMC chipset, it's nice due to it's on board capabilities(EDO, PS/2, ESS 1688, CL5430) so I will use it for programming and playing the original Warcraft. I also got the riser which features ISA and PCI.
It was my first, and maybe last, 486 based purchase after a LONG time.
Reply 28269 of 55583, by respect2759
Today I bought 5 PCs and 5notebooks for 20 euros. Now I need to drive 206 km to get them 🤣
Not so retro, but there is a Thnikpad R50e (one key is missing and the trackpoint too) and a nice IBM desktop. I dont know much about specs, i hope that Phenom 2 is a 4 or 6 core 😊 And one of Acer notebooks is a quad core. None of them have HDDs (was used in a company) 2 notebooks are Asus A6R, I had one years ago, so its a bit nostalgic to me to get one again 😎
Soyo 019R1 AM386DX 40MHz, 8Mb ram, 512Kb Trident 9000 Graphics
S26361-D756-X Intel i486DX 33MHz, 4Mb ram, 512Kb - 1Mb graphics on board
Reply 28270 of 55583, by arncht
my precious is back 😀 it is not "new", but it died. i was very sad, it is very hard to find a late et4000w32p in this condition. i have send it to a friend, and he watched it under the microscope. the original soldering of the main chip was not perfect, they get off, and resolder again. it works again, go back to the socket3 vlb rig!
Socket 3 VLB @ 1994.10 - DX4 100, Tseng Et4000W32p, Sound Blaster Pro 2.0, Gravis Ultrasound, Roland MT-32, Roland SC-55
The attachment 20190416_182231.jpg is no longer available
The attachment 20190416_182305.jpg is no longer available
elcheapo tgui9440 - this is the fast version, the speed is on the same level of the et4000 or the vision864. more details:
DX4 VLB FPS comparison, the fastest VLB video card in DOS
The attachment 20190416_182526.jpg is no longer available
new cpus for the socket3 benchmark.
The attachment 20190416_182701.jpg is no longer available
Overdoze of the demoscene
Reply 28271 of 55583, by havli
Pentium Pro 166/512
K6-2+ 533 and 550
Reply 28272 of 55583, by stalk3r
keropi wrote:
@stalk3r […]
@stalk3r
I have built this and it works perfect
Thanks, I have found this topic on the forum, and will use as a reference for building the cable.
Reply 28273 of 55583, by JonathonWyble
yawetaG wrote:
No, it occurs anytime the right atmospheric conditions are combined with rubbing the fabric that may become loaded with static electricity.
Which, depending on the country, may occur throughout the whole year, and is more likely to occur inside than outside due to heating drying the inside air. 😀
I couldn't agree more. Static electricity can sometimes happen in even the spring and summer seasons. It's also things like that which make me worry about indoor air quality being harmful sometimes.
1998 Pentium II build
Reply 28274 of 55583, by mpe
Nice one.
Got almost identical card:
Blog|NexGen 586|S4
Reply 28275 of 55583, by Anonymous Coward
I have the same Hercules card, with the same soldering problems. I also have a Hercules Trio64 with this problem. I guess it was a quality control problem with this company.
Reply 28276 of 55583, by Merovign
You can find real bargains when a neanderthal chops power cables off things for copper.
(flails uncontrollably)
Don't know how much I'll be able to repair. Got some laptop parts and a couple of stripped but working office machines (always good because people I know often need a "basic pc" for things, so I keep a few around).
Got a GX1 that needs a bath, bad.
I posted a pic of a small part of the carnage on the retro activity thread.
I didn't mention I got a dot matrix printer in the haul as well, seems to have been with the Commodore. It's a very old Oki.
No energy to deal with it all now.
*Too* *many* *things*!
Reply 28277 of 55583, by arncht
yep, i have same experience with the hercules cards - they look very nice, but not too good quality.
Reply 28278 of 55583, by Vegge
Saw this on the local auctionsite and just had to have it.
The attachment IMG_2725s.jpg is no longer available
The attachment IMG_2726s.jpg is no longer available
Dual GPU S3 Trio 64v+. With my thing for dual things this was awesome, have yet to try it though. The cache was from the same seller so I bought that aswell.
Reply 28279 of 55583, by mpe
A great looking card. I presume the second chip just drives the second output and it is not some sort of 2D SLI 😀
Blog|NexGen 586|S4
