DVD accelerators compared
Reply 20 of 42, by Putas
Even plain 6326 has idct decoder. I have one card with DVD chip but it came with C5 bios, not sure if it counts.
Reply 21 of 42, by Scylla
Sorry for reviving an old thread, but I'm building several (at least two of them) retro PCs to keep me entertained and play old games.
I have a couple of those Realmagic Hollywood MPEG-2 decoders. I've never seen them in action, and I don't know if they use any out of the ordinary cables, but I remember them being quite popular at a time.
Are they any good? I may be using them if it's so, to play some DVDs.
Reply 22 of 42, by manbearpig
Bringing this one back from the dead.
Recently got a All in Wonder Pro / ZivaPC powered CineMaster DVD Decoder, from ebay.
It came out of a Gateway Destination, and I don't have the rear panel, so no a/v ins and outs until I can find one.
Performance is great. Although I just use Media Player Classic, it's less quirky than the original CineMaster or ATI software.
This is on a 440LX PII333 machine.
As far as the best DVD decoder goes, it should be something with a C Cube Microsystems chip on it, as they were at the top of that game. Of course, all implementations of those chips are most likely not equal.
Premio 212B motherboard (MSI MS-6112)
Intel PentiumII 333MHz Slot 1 66MHz bus
384MB ECC 66MHz
SIIG ATA133 controller --> Seagate Barracuda 80GB
SIIG Gigabit Ethernet (RTL8169) / USB 2.0 / IEEE1394 controller
ESS 1869 soundcard on board wavetable synth
Reply 23 of 42, by GL1zdA
Does anyone know why Apple decided to ship the G3 Macintoshes with C-Cube ZiVa decoders when the ATI 128 they've used already accelerated DVD decoding?
getquake.gif | InfoWorld/PC Magazine Indices
Reply 24 of 42, by 386SX
edit next post
Reply 25 of 42, by 386SX
Trying the Dxr3 on Athlon 1000 / KT133 / Win9x/ME and for vga strenght and quality with the G400. I am using a CRT (17"), a must for these cards. Everything is compatible and no crash or problems I had with other configs.
Now through the analog pass cable and overlay chip/own filters, you could expect a bit of smoothness. It seems that the graphic card output quality plus the combination of resolution/vertical freq could improve or lower the quality a bit.
The decoding quality, with this consideration, is really good in my opinion. I like there're no external options to add more noise removing/sharpening like recent solutions to mix the already few source pixels, no octa-core processing to make it like-hd, but everything is probably done in hardware just as much as needed (the board processor is certainly working finger tested 😁). Nice is the really smooth and -stable speed- playback and lag free decoding not to mention the free cpu cycles.
Reply 26 of 42, by 386SX
I am trying the EM847x Realmagic X card pci comparing to the previous EM8300 solutions. Interesting and different solution, some opinions later.
Reply 27 of 42, by Skyscraper
I am also testing the REALmagic Xcard right now.
Im very impressed with the DVD decoding, even with a PII @ 133 MHz with disabled L2 cache the decoding is perfect. The MPEG4 decoding is also OK but the included REALmagic MPEG4 codec is 32bit only, I have to use Virtual Dub 32bit to do the encoding on my main system running Windows 7 64. If I do not use AviSynth Im limited to 2GB AVI source files and to make matters worse 32bit Virtual Dub do not really like X264 as a source so Im using Xvid as the intermediate codec which degrades the quality. Decoding old DivX 3/4/5 files seems to work fine as long as the files are not encoded with certain advanced features.
Reply 28 of 42, by 386SX
Happy that someone has got it to ask some things. The latest win9x drivers are the one of december 2003 with the application a bit older?
It' really a nice card; I'm switching from the EM83xx based chipset card and I would think something changed from the old overlay crt concept for better tv/lcd experience. I've the feeling like the card not composing the video card/decoder output but more like switching between them to output a clearer/detailed picture in both desktop and full screen. But I don't understand if the 720p resolution is actually 1280x768 or what, and maybe there's a way to scale it at the exact 1024x768 to better compare them. On the CRT I would think there's a bit more aliasing in video than the EM83xx probably cause I don't find a way to set it at 1024x768 as the old but limited to the configuration options. I would have liked to have a list of possible resolutions to set but I understand that this would be needed only on the CRT that was already at its technological end.
Reply 29 of 42, by Skyscraper
It' really a nice card; I'm switching from the EM83xx based chipset card and I would think something changed from the old vga overlay crt concept for better (hd)tv/lcd experience. I've the feeling like the card not composing the video card/decoder output but more like switching between them to output a clearer/detailed picture in both desktop and full screen. But I don't understand if the 720p resolution is actually 1280x768 or what, and maybe there's a way to scale it at the exact 1024x768 to better compare them. On the CRT I would think there's a bit more aliasing in video than the EM83xx probably cause I don't find a way to set it at 1024x768 as the old but limited to the configuration options. I would have liked to have a list of possible resolutions to set but I understand that this would be needed only on the CRT that was already at its technological end.
I have been using the 21/2.1 driver from 2002 as it came in a complete package with the Xmedia player and configuration utilities. I do not know what the 21w1/2.1W1 driver from 2003 improved but I have it downloaded. Im using a 1280*1024 17" TFT to show the video using the Xcards "VGA 720p/60Hz" output setting. I have no idea what exact resolution the output is but it looks sharp with a good DVD and definitely better than the 480P output setting, at least with a screen that cant show any of the output resolutions pixel perfect.
In case someone needs it this is the package for Windows 9x Im using.
The attachment Xcard_9x._full_package_tested_working.zip is no longer available
Reply 30 of 42, by 386SX
I am using the late 2003 one and the only newer I have found. I can't compare the best setting (720p/72hz, using CRT the 60hz will be difficult) if I don't understand the exact resolution. It look like 1024x768 or ...x720 but, probably it's my cheap crt monitor the aliasing would seems to be still a bit more than the overlayed. It's great let me say, sharp, stable and clear but I would like to find a way to better configure 4:3 CRT output.
In your case I imagine your TFT monitor scaler doing some processing to full-screen the final image, doesn't it?
Reply 31 of 42, by Skyscraper
If the Xcards 720p output isnt 1280*1024 (which it isnt) my Acer TFT will do some processing and scaling, this screen wont show anything that isnt its native resolution without scaling.
At high resolutiuon (720P) the scaling wont degrade a low resolution source like a DVD as much as it does at the lower 480P resolution output setting though.
Reply 32 of 42, by 386SX
Update: problem solved, as I thought it was my CRT monitor the problem going out of standard resolution! Now is running as the desktop and quality is impressive! I always liked these hw decoder cards and this is great.
Reply 33 of 42, by dr.zeissler
Hi is there any solution that does not require a vga-pass-through and does not use a vga/vesa feature connector?
In my setup I route the VGA-Signal from the onboard-gpu (matrox G100a) to the voodoo1 card. If the VGA-signal must be routet through another vga-loop-cable the image-quality will be worse.
I have a PCI or an ISA Slot free.
I want to get Hardware MPEG Video Acceleration for retro-games and for single video-files (not only for full-dvd playback)
Thx
Doc
Reply 34 of 42, by NJRoadfan
Use AviSynth as a frameserver for VirtualDub to handle the h.264 files. 32-bit VirtualDub works fine with 2+GB AVI files, the problem is that you are working with files on a FAT32 partition that only supports 2GB max files.
Reply 35 of 42, by Baoran
At least this was only a 3-6 year old thread...
Reply 36 of 42, by uridium
Anyone know where you can get the DVD Player software for the Creative Dxr2? Currently playing around with one. 😀
Reply 37 of 42, by elianda
I am not 100% sure, but
ftp://retronn.de/driver/Creative/PC-DVD_DXR2/
and this player
ftp://retronn.de/driver/Creative/DVD_Player_3.50/
Youtube Channel
Reply 38 of 42, by uridium
Ah! Wonderful thanks 😀 Got it down. Will give it a go tonight.
Much appreciated!
Reply 39 of 42, by Warlord
would like to have seen a comparison including sigma designs offerings.Like the Xcard,and holywood plus.
