DOSBox Icon
First post, by robertmo
It is a box.
It is old.
It reminds many games like: Alone in The Dark, Monkey Island, Heroes of Might and Magic, Betrayal at Krondor, etc.
DOSBox is actually a treasure chest, full of different emulated sound cards, graphic cards etc.
And it allows us to play our old treasures - old dos games.
And it looks nice.
Reply 1 of 333, by DosFreak
Well it's simple, easy to understand but I dunno....Personally I think "chest" when looking at it...and I see your point about it being a treasure chest. Mabye I'm just overanalyzing.
Make your games work offline
Reply 2 of 333, by ChaosFish
Nice concept.
I think, though, an icon shouldn't have much "hidden meanings". Although it's cool, it doesn't remind me anything of DOS at first sight, and first sight is the most important thing about an icon.
So if you could make an icon that somehow combines a box and DOS at the same time, I think that would be better.
Just my 2 israeli shekels 😉
Reply 3 of 333, by eL_PuSHeR
It's nice and sure it holds some work involved but I agree with what ChaosFish said...
And moving to DOSBox General, by the way (what has this to do with Development?)
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 333, by robertmo
I agree that it should have both dos and box.
Although if you look at other icons it is not that often used.
Generally the icon is so small that it mostly allows only 4 things:
1. A large letter - it could be "D"
-Opera has "O"
-Internet Explorer has "e"
-Alcohol has "A"
2. Part of a name or the whole name - it could be:
DOS
BOX
-LanChat
-Gens
-mIRC
3. A picture - can be a box
-ACDSee has an eye
-WinRAR has books
-Total Commander has a floppy
-eMule has a mule
4. Combinations of two pictures also exists
-Nero has a CD in flames
-WinImage has a floppy with a camera
5. As a DOS part is rather abstract so it requires a combination of a picture and text which is rather difficult.
Reply 5 of 333, by avatar_58
I personally use this
Reply 6 of 333, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
just to be nitpicky, Nero has the burning Colloseum 😀
Reply 7 of 333, by Targaff
And do you have it in an icon format? 😉
Mine's similar, actually - just a black box with a c:\> command prompt in it.
Intel CC820 | PIII 667 | 2x128MB SDRAM | 3Dfx Voodoo 5 5500 @ Dell P790 | Creative SB PCI128 | Fujitsu MPC3064AT 6GB + QUANTUM FIREBALLlct10 10 GB | SAMSUNG DVD-ROM SD-608 | IOMEGA ZIP 100 | Realtek RTL8139C | Agere Win Modem
Reply 8 of 333, by ChaosFish
How about an open box, that has:
C:\>
Lying diagonally in it?
Reply 9 of 333, by Gene Wirchenko
[quote="ChaosFish"]Nice concept.
Just my 2 israeli shekels 😉[/quote]
What about a building block viewed from one corner with one letter on each visible face? Now, modify the block so that it is a cardboard box.
Sincerely,
Gene Wirchenko
Reply 11 of 333, by avatar_58
I got a little bored...
Reply 12 of 333, by ChaosFish
avatar: You're in the right path! Just need to make the box more "box like" and having it all a bit more realistic and you're there!
Reply 13 of 333, by avatar_58
I could, problem being is that at such a small size an icon is a little hard to detail. (In other words that was a real box in its original size but once I shrunk it down it was hard to see) 😅
Reply 15 of 333, by HunterZ
Use the code tag:
 B
DOS
X
Reply 16 of 333, by robertmo
DosFreak: no nead to repeat others' ideas 😉
Reply 18 of 333, by Qbix
Rank DOSBox Author
DOSBox Author
HunterZ wrote:
Use the code tag: […]
Use the code tag:
 B
DOS
X
anybody able to translate this into an icon ?
Wonder how it will look like.
Water flows down the stream
Reply 19 of 333, by ChaosFish
I made this. It lacks quality, so think of it as an icon idea 😀
The space inside the "O" is transparent (i.e. you can view the desktop through it)
