Reply 7180 of 31809, by OldCat
- Member
wrote:wrote:Dismantled my Toshiba T3200sx in order to replace Conner drive with CF card. Turned out more challenging than I thought, so it is still in progress.
The 5200 has a BIOS limitation where you can only put in a Conner drive of the same size than the one the computer originally came with. Doesn't the T3200 have that limitation too?
Had to use a XTIDE CF in mine - which can only do 8-bit transfers, but the non-existent seek time makes up for it.
Yes, but it's still feasible. I have T5100 running off CF card and the gentleman who taught me much about retro computers has T3100 done the same way. I hope that in couple days / weeks I will be able to show you working T3200SX as a proof. 😀
