First post, by agent_x007
- Oldbie
Hello all 😀
Challenge :
Build a universal Retro PC for DOS/Win98SE/WinXP/Win7/Win10 [x64].
Native support. No DOSBox/Virtualisation/etc.
Basicly : "The Impossible stuff" 😁
Well, I gave it a shot... and here are the results :
DOS 6.22 :
Windows 98 SE :
Windows 2000 :
Windows XP :
Windows 7 x64 SP1 :
Windows Server 2016 (Win 10+) :
DirectX 12 support test : https://www.3dmark.com/spy/2555135
Checked, and Valid 😀
I added Win2000 and Server 2016 to make it even more ridiculus/compatible 😁
Hardware list :
CPU : Core i7 980X (w/BOX cooling)
MB : Rampage II Extreme (BIOS 2101)
RAM : Corsair 3x4GB
GPU1 : GeForce 7800 GTX (Reference)
GPU2 : GeForce GTX 780 Ti (Reference)
SC1 : Aureal Vortex 2
SC2 : Auzen X-Fi Forte
HDD0 : Compact Flash 1GB
HDD1 : WD Raptor 74GB
HDD2 : WD RaptorX 150GB
HDD3 : Samsung SM961 256GB (NVMe)
Clover "Pendrive" (card reader + microSD) : Sandisk 8GB
PSU : OCZ ZS-750W
Floppy : GOTEK USB Floppy Emulator
Pics :
Working : LINK
PCI(e) Devices : LINK
Slot vs. Device :
PCIe x1 = "Empty"
PCIe x16 2.0 "1" = 7800 GTX
PCIe x1 "2" = X-Fi Forte
PCIe x16 2.0 "2" @ x8 = NVMe
PCI = Aureal Vortex 2
PCIe x16 2.0 "3" @ x8 = GTX 780 Ti
Notes :
1) rlowe patch NOT required if you can live with 1GB RAM on Windows 7/10 😁
2) No CD's were used during OS installation (card readers + microSD FTW 😉).
3) Sound works in ALL OS-es (DOS <=> Win2000 = Aureal Vortex 2; WinXP <=> WinServer '16 = X-Fi Forte)
4) GTX 780 Ti will not work with 7900 GTX on Windows 98SE (if moded drivers are used).
Reason : NV driver falls apart if it sees 512MB of VRAM and another card. Unplugging GTX 780 Ti solves this issue.
5) Quadro FX-1300/6800 GT will not work in Win2000 because of AGP to PCI-e bridge conflict with MB's PCIe to PCI brudge.
6) GTX 780 Ti uses PCI-e 2.0 x8 slot (and since it's Dual Slot card, it requires some space below last slot if this setup had to be mounted in actual case).
I made a video how it all works as well : LINK
Enjoy 😀
Conclusion :
I know this can't run really old games because of CPU speed sensitivity [Core i7 980X can go as low as 1,2GHz with 100MHz BCLK], or those that are simply not compatible with GF 7800 GTX in DOS mode.
I wanted to showcase a working PC that can do modern things but that is capable of running retro programs (up to a point).
UPDATE (07.11.2017) : LINK
Current configuration :
RAM : Corsair 3x4GB (12GB total)
SC1 : Aureal Vortex 2 + DreamBlaster X2
HDD0 : Transcend Industrial Ultra 1GB (Compact Flash) [DOS 6.22]
HDD1 : WD Raptor 74GB [Win 98 SE]
HDD2 : Kingston SM2280S3G2 (M.2 AHCI/SATA) [Windows 2000 SP4 + Windows XP SP3]
HDD3 : Samsung SM961 256GB (NVMe) [Windows 7 x64 SP1 + Windows Server 2016]
"Pendrive" (card reader + microSD) : Sandisk 8GB [Clover]
PSU : OCZ ZS-750W
