First post, by m5215tx
- Member
I am seeking some advice/opinions on this...
Would it be worthwhile to consider acquiring the SC88 Pro or would that be mostly redundant since I already have the SC-88 VL?
Also, one thing that concerns me is that these larger sound modules often have the power supply *inside* the unit itself. I would much rather have an external power supply so if a power surge kills the power supply it is easy to replace. I would imagine that finding a replacement internal power supply for these older sound modules would not be easy.
Roland MT-32 (old), CM-32LN, SC-55, SC-88VL, MT-120, SD-35, SD-20, SD-80, SD-90
Yamaha TG100, TG300, MDF2, MU15, MU100, MU2000EX + PLG150-DR + PLG150-PF + PLG150-VL
KORG NS5R, X5DR
AKAI SG01k
KAWAI GMega
KETRON SD2
