First post, by squareguy
I just ordered a few AOpen Cobra YMF-744 sound cards on eBay knowing that they do not have the SB-Link header installed. I am planning on possibly using one on a new DirectX 7.0 build and I would like the SB-Link to work for late DOS games and just because.
It looks like the header (IDC 6-pin) and at least two SMD componets (capacitors and/or resistors) will need to be installed. Anyone done something similar or know the values of the missing components?
Here are the pics from the eBay auction
The attachment s-l1600 (3).jpg is no longer available
The attachment s-l1600 (2).jpg is no longer available
The attachment s-l1600 (4).jpg is no longer available
Intel SE440BX-2 Motherboard
Intel Pentium III 450 CPU
Micron 384MB SDRAM (3x128)
Windows 98 SE
Reply 2 of 38, by squareguy
Awesome, thanks!
Hopefully it's just those three parts
Windows 98 SE
Reply 3 of 38, by gdjacobs
You'll notice that the traces between the header and the YMF744 are intact, so those components are for pull up, pull down, or noise suppression.
Reply 4 of 38, by squareguy
Well they arrive today and I should be able to get better pics by tomorrow.
Windows 98 SE
Reply 5 of 38, by squareguy
I am assuming this is a reference card design. If anyone has a YMF744 card that looks similar with the SB-Link and / or SPDIF installed please post some high-res pics. My searches have not yielded much.
Windows 98 SE
Reply 6 of 38, by SaxxonPike
I've picked up a 754 from Labway recently with a very similar PCB. I'll get photos.
Sound device guides:
Sound Blaster
Aztech
OPL3-SA
Reply 7 of 38, by squareguy
Thanks!
Windows 98 SE
Reply 8 of 38, by SaxxonPike
I guess my PCB isn't as similar as I'd thought.. here are some photos anyhow. Sorry they couldn't be more useful :s
The attachment photo_2017-08-14_10-21-33.jpg is no longer available
Above is the SPDIF header.
The attachment photo_2017-08-14_10-21-32.jpg is no longer available
Above is the PC/PCI header. The two components labeled R44 and R47 have "103" printed on them. Pins 92-94 on the 754 appear to have discrete connections to the header, but I can't tell which is which because they go underneath.
The attachment photo_2017-08-14_10-21-27.jpg is no longer available
The bottom side doesn't appear to have traces for this connector on this PCB.
Sound Blaster
Aztech
OPL3-SA
Reply 9 of 38, by squareguy
SaxxonPike & cyclone3d
Well at least it confirms that the two resistors are 103 (10k-Ohm) from more than one source.
I think those are the only two missing componets other than the header. I will trace C16 on my board when it arrives to double check.
Thanks again! BTW how do you like that card and what do you use it for, if anything?
Windows 98 SE
Reply 10 of 38, by SaxxonPike
squareguy wrote:
SaxxonPike & cyclone3d […]
I'm still waiting on a replacement PlatiniX 7LI-A motherboard, which should contain a PC/PCI connector. They sent me the C variant, which lacks the PC/PCI connector. Ideally, I would test this card for my Pentium 4 DOS gaming article.
Currently, the card isn't being used for much of anything 😀
Sound Blaster
Aztech
OPL3-SA
Reply 11 of 38, by squareguy
I will try and test soon. resistors check good though.
The attachment 2.jpg is no longer available
The attachment 3.jpg is no longer available
The attachment 4.jpg is no longer available
Windows 98 SE
Reply 12 of 38, by squareguy
I got a chance today to test it. Took a little bit to figure it out but working fine under pure DOS with S-IRQ and PC-PCI (SB-Link)
Pretty cool!
Windows 98 SE
Reply 13 of 38, by gdjacobs
Sweet. Now you have to figure out SPDIF I/O!
Reply 14 of 38, by SaxxonPike
Excellent! Thanks for performing this experiment.
Sound Blaster
Aztech
OPL3-SA
Reply 15 of 38, by Muz
Does it has OPL3 sound in the Windows environment?
Reply 16 of 38, by Lawro
Pretty cool!
I just got one of these, and am super interested in soldering on the header and resistors like you did.
I was wondering if you recall the power rating and tolerance of the 103s you used? I don't know much about that sort of stuff and don't want to use ones that'll break the card.
Reply 17 of 38, by squareguy
I'll try to measure them and see what size they are, I have forgotten honestly.
Windows 98 SE
Reply 18 of 38, by squareguy
10k-Ohm 805 SMD Resistors
Windows 98 SE
Reply 19 of 38, by vutt
I'd like to thank you guys for this mod info. Now I have fully functional SB Pro in native DOS mode. I like this card very much in both win98 and DOS op.systems.
My rig: https://imgur.com/5LSXDcx
